Reply
Old 01-02-2020, 06:19 PM
VotbKartting VotbKartting is offline
Junior Member
Default Right angle drive belt/torque converter
new here
just an idea
please leave feedback
pros and cons to design
thank you
HTML Code:
<a href="https://imgbb.com/"><img src="https://i.ibb.co/MZNHTMN/Screen-Shot-2020-01-02-at-7-11-01-PM.png" alt="Screen-Shot-2020-01-02-at-7-11-01-PM" border="0"></a>
HTML Code:
<a href="https://imgbb.com/"><img src="https://i.ibb.co/TtcPg4f/Screen-Shot-2020-01-02-at-6-07-32-PM.png" alt="Screen-Shot-2020-01-02-at-6-07-32-PM" border="0"></a>
Old 01-02-2020, 07:07 PM
BigWes's Avatar
BigWes BigWes is offline
Uneven sideload on the belt...over time as it stretches it will leave the pulley grooves... probably sooner than later.
This concept will work with something round like steel cable...I don't know how effective or reliable it would be under load.
This ain't rocket science boys!!!
The Following User Says Thank You to BigWes For This Useful Post:
VotbKartting (01-02-2020)
Old 01-02-2020, 07:21 PM
Junior Member
thanks for getting back to me!
can you explain "sideload" to me?
ive searched google cant find and thing that pertains to it
Old 01-02-2020, 07:50 PM
itsid's Avatar
itsid itsid is online now
Nah that won't work well with a Torque converter.
The principle of a torque converter is mainly that the effective diameter of the
pulleys change.
In order to do so more often than not the belt will have to move laterally
even asymetric setups (like the series 30) has the "straight" sheave angled and
thus a belt that moves laterally.
And while that belt offset is small it's not really negligible.
And now the worst part:
the belt itself is rather stiff, it would NOT like to get bend around a corner that way.
And while you may be able to force it into that shape of course,
it'll retaliate
TCs have a rather bad efficiency (at best maybe 80%) if you force the belt
into any sort of bend, that will drop dramatically (a pulley offset alone can cause another 20% drop..
and you only have 55-60% of the motor power to your disposal.
AAND the belt itself will fail prematurely because of the additional stress.
the guiding pulley would need to be huge in order to keep the stress (and powerloss) down.
Also that pulley would need to move along it's axle in order to keep up with the belt moving up and down.
A right angle gearbox is far less complicated and far more reliable IYAM
Old 01-02-2020, 08:02 PM
Junior Member
Default Quarter Turn Belt Drive
say it was not a torque converter just a quarter-turn v belt drive like so
Quarter Turn Belt Drive : The quarter turn drive always known as right angle belt drive, is used with shafts arranged at right angles and rotating in one definite direction. In order to prevent the belt from leaving the pulley, the width of the face of the pulley should be greater or equal to 1.4 b, where b- is the width of the belt. when the reversible motion is desired, then a quarter turn belt drive with guide pulley.
https://ibb.co/JqdYTJL
---------- Post added at 09:02 PM ---------- Previous post was at 08:58 PM ----------
also can you suggest a good 1:1 right angle gearbox
Last edited by VotbKartting; 01-02-2020 at 08:09 PM. Reason: More information on topic
Old 01-02-2020, 09:14 PM
itsid's Avatar
All quarter turn belts I remember have been flat belts (no v belt.. more a leather strip really)
the thickness of the belt will always be an issue,
it just doesn't like to get bent or twisted.
And forcing it will cause heat (aka powerloss, thus premature wear)
PS just take a look at industrial RAGBs and I'm sure you'll eventually find one rated for your required hp and speed.
  #7
Old 01-03-2020, 07:55 AM
BigWes's Avatar
Right angle gearbox is a better option. You can probably source one at a reasonable price at a farm store. If it can handle the demands of a piece of heavy equipment a lightweight kart shouldn't be an issue. Just take into account any ratios or RPM requirements.
  #8
Old 01-03-2020, 08:12 AM
JTSpeedDemon's Avatar
2019 Build Off Winner!
Some vertical shaft engine-edgers utilize a twisted belt setup, I saw one just yesterday. NOT like the one in the picture, it's just the best I could find with an image search. The setup I see on edgers has less twist so the power is transmitted from the vertical to horizontal plane, with both turning the same direction(pulleys at 90 degrees in relation to each other).
It might kind of work for your purposes, I don't know.
BTW - What are you doing that needs that kind of setup???
Currently Flathead-Crazed
  #9
Old 01-03-2020, 10:12 AM
anickode's Avatar
anickode anickode is offline
That setup is called a Mule Drive, and can be done with a long V belt, but it will not work with a short, stiff torque converter belt. There is on on nearly every lawn tractor in some form or another.
Mule drives are also big time power-suckers. I run one on my rat wagon and there's so much friction loss in the driveline that the back wheels don't want to roll when you push it.
"Well that would be a bomb."
The Following 2 Users Say Thank You to anickode For This Useful Post:
JTSpeedDemon (01-03-2020), VotbKartting (01-13-2020)
  #10
Old 01-13-2020, 04:28 PM
Junior Member
thinking about mounting a predator vtwin on the front of a go kart
but the want the v to be parallel to the back axle
  #11
Old 01-13-2020, 04:52 PM
Your best bet will probably be a driveshaft of some sort running under the driver. Seems a little ambitious. Does it have to be in the front? Is it some kind of hot rod theme go kart?
Reply
