Reply
Old 10-31-2019, 07:31 AM
slowJEEP's Avatar
slowJEEP slowJEEP is offline
Default ISO small transmission ideas
Designing a small cart (similar to mini/dwarf/midget sprint cars) for the fun of it. May never make it off of the computer screen. I've been basing the design on a 4cyl 4 stroke jet ski motor my friend gave me.
I'm having trouble coming up with an elegant way to do the transmission.
Right now, I have a shaft from the motor going to a rear mounted CVT/gearbox (with rev)/ATV diff. I don't really like how it's come together. A multi speed transmission from a 1L car would be great but I'm having trouble finding one.
Surely something exists that weights 30-50 lbs and has at least 3 fwd gears and 1 reverse. I need to check on the Suzuki jimny again.
Has anyone seen something that'd fit the bill? I can make adapters and whatnot.
All the best,
Jim
Cheap Bastard Garage
Jim in Florida
---------- Post added at 07:31 AM ---------- Previous post was at 07:24 AM ----------
I think the Jimny and samurai transmissions are about the same. Internet said samurai trans weighs 62lbs.
Jimny trans in the picture. It's gotta be overkill but getting close. A solid plan B at worst.
Jim in Florida
Old 10-31-2019, 07:45 AM
anickode's Avatar
anickode anickode is online now
Is reverse a must? A divorced trans for a Harley type motorcycle might work.
Honda goldwing too, and they're shaft drive out, designed for a longitudinally mounted engine.
Personally, I'd probably ditch the jet ski engine and just get a shaft drive motorcycle setup. Honda CB700 for example. In this instance, (as with most go karts) buying a more suitable engine will be cheaperr than trying to build around something you got for free.
"Well that would be a bomb."
The Following User Says Thank You to anickode For This Useful Post:
slowJEEP (10-31-2019)
Old 10-31-2019, 08:18 AM
slowJEEP's Avatar
https://youtu.be/pQqILYoHA18
This trans seems plausible. Can get them from Japan.
I agree on finding a different motor. Unless I can figure out a reason this setup is better than a sportbike/chaindrive/live axle, I'll can it. I have in my head that there's something this motor must be better at than the aforementioned setup.
I have a disproportionately large amount of time to think/draw vs wrench. I'm gonna keep working this idea to see if I can turn it into something worth while.
Thanks for the input.
Jim in Florida
Old 10-31-2019, 08:29 AM
Smerft85 Smerft85 is offline
I don't know about your area, but jimnys and samurai/sidekick/trackers are getting rarer, and I know first hand, I've sold salvage parts for trackers and sidekicks for almost 10 years now, and I have zero transmissions for sale. They are fairly lightweight, but very long and most have a t-case for 4x4. I would look more into a quad with reverse or dirtbike ect if reverse is not important.
The Following User Says Thank You to Smerft85 For This Useful Post:
Old 10-31-2019, 08:58 AM
Deadbeef Deadbeef is offline
Take a 4 wheeler engine that is shaft out put would be the easy route although maybe expensive.
Or a dirt / motorcycle engine turned 90 so you can run a chain to a drive shaft down to the rear diff which might have to be flipped upside down.
I have thought of a lot of ideas for my awd kart, so just helping to keep the idea alive!
The Following User Says Thank You to Deadbeef For This Useful Post:
Old 10-31-2019, 11:12 AM
slowJEEP's Avatar
Thanks for sticking with me on this thought exercise. Here's the Jimny trans in lieu of the previous drivetrain. It looks a lot better.
The wave runner motors are cool bc they are meant to get wet, designed to maintain high rpm for extended periods, are tough/reliable and everywhere in my area.
Not pleased with how far forward the CG looks to fall, maybe I can coax it rearward.
Quick look shows a Jimny trans can be had for around $800 after shipping from Japan. Not cheap but not a show stopper of everything else pans out.
Until next time,
Jim
Jim in Florida
Reply
