Old 09-23-2018, 10:57 AM
4EyedTurd 4EyedTurd is offline
Default GY6 150 flywheel differences or wrong part?
I bought an older Trailmaster buggy with the GY6 150cc motor that does not have any spark. Using a trouble shooting guide I believe it's the stator that is causing the lack of spark. The motor has a 6 pole stator and from what I've seen an 8 pole is an upgrade. So, I ordered an 8 pole stator and flywheel but the flywheel won't fit the shaft. The flywheel hole is smaller but the stator bolts on fine.
Has anyone ran into this?
