  #61
Old 11-03-2018, 02:06 PM
Ognib's Avatar
Ognib Ognib is offline
bingo spelled backwards
The backing plate is still long & the corners don't yet fit in between the tube ends, so the upper arm is off of level.
Mock ups give a visual "feel" as to how it's coming together.
My brain is the key that sets me free. Houdini
  #62
Old 11-18-2018, 10:42 AM
Ognib's Avatar
Cut some plugs off of a piece of bar stock.
These are for the ball joint bosses.
Need a couple of v blocks for set up on the mill, to hold them securely.
Will be facing the ends & squaring to the sides before drilling & boring the taper to match the ball joint studs.
Toolmakers vice pulls the jaw down while clamping...this eliminates the dreaded "jaw lift", helping to maintain an accurate setup.
  #63
Old 11-18-2018, 02:32 PM
Ognib's Avatar
This setup worked well.
  #64
Old 11-20-2018, 11:15 AM
Ognib's Avatar
Got a new face mill cutter...much quicker than using a 1/2" end mill for this type work.
Leaves a visable pattern on the steel, but the feel is that of polished metal.
  #65
Old 11-24-2018, 10:51 AM
Ognib's Avatar
Boring ball joint stud tapers today.
Found an old guy about my age that has a small one man grind shop.
He mfgs machine cutting tools & sharpens drill & mill bits.
Took him a fresh 3/4", 4 flute end mill along with my measurements & he tapered it to my specs.
Fits perfect...
  #66
Old 12-01-2018, 12:33 PM
Ognib's Avatar
Start fitting the ball joint bosses to the backing plates.
But first, a massive cleanup.
  #67
Old 12-02-2018, 11:12 AM
Ognib's Avatar
With a couple of the now completed bosses in place, I'm still using the paper template for verifying dimensions.
Straps will act as stiffeners, helping to eliminate flex at the tips of the plate.
Angles will keep the two ends in good alignment while assembling, as well as keeping side straps square with the plate during the process.
Slider gauge, used from side to side will assure that it's all centered on the plate.
The Following User Says Thank You to Ognib For This Useful Post:
ezcome-ezgo (12-03-2018)
  #68
Old 12-06-2018, 10:27 AM
Ognib's Avatar
My hubs are 5 lug...my wheels are 4X4".
Put the hubs in the press & pushed it all apart in preparation for re-drilling.
I bought all of the parts cheaply enough that I was cool with the work involved in changing the lug pattern...I've got more time than money these days.
Get the caliper out & do some measuring & draw up a layout.
Then set up the rotary table on the mill & see what I can come up with.
landuse (12-07-2018)
  #69
Old 12-07-2018, 05:57 AM
LightningTeg's Avatar
This thing is going to be an animal! Nice work
  #70
Old 12-09-2018, 12:41 PM
Ognib's Avatar
Thanks, giving it my best shot.
The rotary table & chuck were full of chips wet with cutting oil from previous work.
Broke it all down & cleaned it up for this work.
Measured the flange & drew a plan to scale.
Did the layout work & checked it...perfect 4" span for center of the stud holes.
It appears that I will be able to use one of the existing holes as the line drops right into their centers.
ezcome-ezgo (12-10-2018)
  #71
Old 12-13-2018, 01:39 PM
Ognib's Avatar
Setting up the rotary table for re drilling the lug bolt pattern.
My rough setup is using a countersink...I put a drop of layout dye on the edges & lower the bit into the hole & rotate it backwards by hand... adjusting the x/y axis on the table until it wipes the dye off cleanly.
Then I set the indicator & rotate it from side to side & front to back... adjusting the table x/y until I get a consistent reading all around.
At this point my setup is within a half a thou of being centered with the spindle centerline.
Then the chuck goes on top of that & the same procedure is employed.
The goal is that when the flange is mounted & centered for drilling, the drill bit will be on my layout line consistently as I rotate the setup from one drilling position to the next.
Slow going for me as I've only been doing machine work for about 2 1/2 yrs & I have a tendency to keep going back & re checking my work.
ezcome-ezgo (12-14-2018)
  #72
Old 12-15-2018, 04:28 PM
Ognib's Avatar
Got the first hub drilled. Couple of the holes are close to the originals but my guesstimate is that the car they came off of probably weighed 3,000 lb ish. I'm tracking the weight of my tubing, engine & components & I'm figuring the buggy will be in the 500-600 lb range, dry, before fluids & driver. Should be plenty good.
Fresh grease on the bearings & get the studs in & everything pressed back together & can get the hub bolted to a wheel.
That will hold the hub in position for a more accurate fit up to the ball joints.
Progress!
  #73
Old 12-16-2018, 10:10 AM
Ognib's Avatar
5 to 4. Result of several days work. Fits good. Happy with the results.
Now that everything's solidly mocked up I can finalize my dimensions . I can already see that the upper & lower control arms are needing to be a bit closer together...don't want them rubbing against the wheel edge during suspension travel.
Sorry about the poor lighting...my fluorescent bank back here quit. Need to get a new ballast.
  #74
Old 04-12-2019, 07:52 AM
Ognib's Avatar
https://grassrootsmotorsports.com/fo.../149874/page1/
