Old 10-24-2010, 04:21 PM
Suicidaltendencies Suicidaltendencies is offline
Default Multi gear weed whacker powered bicycle
As the title says: I wanna make a multispeed bike. I have a mountian bike sitting in my backyard. I also have a weedwacker that was written off by my dad as dead so i have takin it in and got it running, now i wonder if it is possible to mount the engine to the bike and use the rear gears of the bike still.
Old 10-24-2010, 04:28 PM
devino246's Avatar
devino246 devino246 is offline
Official DIYGK Chem Nerd
Bike gears wont be able to stand up to the RPM of the weedeater engine.
ASE Certified
The Following User Says Thank You to devino246 For This Useful Post:
Suicidaltendencies (10-24-2010)
Old 10-24-2010, 04:35 PM
Dang. well thats why i asked
Old 10-24-2010, 04:46 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
AZUSA:Powered by LAWN-BOY
Weedie engines do not produce a lot of power.
Should work if properly planned out. Centrifugal clutch is a must. The fewer the teeth...the better.
Engine should be mounted to drive the pedal sprocket. The rest is cake.
https://www.youtube.com/watch?v=c4jch0puM1A
Old 10-24-2010, 05:10 PM
devino246's Avatar
Considering the amount of offset between multi-speed bike sprockets, i would think the chain would frequently jump. Although, if its geared down to near-human speeds, I suppose it would work.
ASE Certified
Old 10-24-2010, 05:26 PM
Russ2251's Avatar
Again...If planned properly, it will work.
RPM must be kept low when shifting.
Old 10-24-2010, 07:08 PM
Doc Sprocket's Avatar
RPM has to be calculated, but I would think the engine would have to drive a jackshaft for a primary reduction, then the jackshaft would drive say, the larger sprocket on the crank, then the smaller sprocket would go to the wheel. You'd lose the high-low shift, but retain the shifting at the rearend. Alternately, if you could find a way to add another sprocket to the pedal crank, the engine could drive IT, leaving the factory shifting intact.
Old 10-24-2010, 07:35 PM
Well the pedals have 3 gears the rear has 8 so ill see what i can think up
Old 10-24-2010, 07:36 PM
Russ2251's Avatar
Use the largest of the 3 to start.
Old 10-24-2010, 07:38 PM
Will do
  #11
Old 10-25-2010, 03:56 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
Keep in mind most gears on a bike are overdrive gears, so a lot of reduction will be needed before you apply power to the bikes crank.
  #12
Old 10-25-2010, 04:05 PM
GreyhoundOfYerfDogs GreyhoundOfYerfDogs is offline
I did this as a teen with a strange off-brand engine I had found in an alley (small 4 stroke.) Rather than use the bicycle gears I used a rubber wheel about 4" diameter bearing against the rear tire. Using scrounged parts only, the gearing wasn't good at all, but it would propel my bike along faster than I could pedal. Running through even a little water made the wheel slip. If I did it again, a better drive wheel would probably solve these issues; rock-hard solid rubber with grooves is NOT the hot tip. Using the bicycle gears isn't that great of a plan unless you can get some mad reduction gearing.
Stock Yerf-dog 3203, Project Yerf-dog 3209 13hp; Quads: Honda 250, 400, Kawasaki KFX700
First kart built 1981, 2.5 horse Briggs and frame made of 2X4s
  #13
Old 10-25-2010, 04:59 PM
robbie robbie is offline
If your engine drives the largest sprocket on the pedal assembly I think you could make it work.
When you cruise on a normal mini bike and then let off the throttle, the spinning wheel keeps the clutch engaged until you slow down enough for it to let go. On a bike, the pedals drive the wheel but not the other way around. This would allow you to release your throttle and coast. Then you could probably shift gears with little engine bursts, without everything going bonkers the whole time you're moving.
If you set up the engine to drive the large pedal sprocket, you can use the two smaller sprockets as normal. You may need a reduction between the engine and the pedal sprocket, but that's another issue.
  #14
Old 10-25-2010, 06:08 PM
Russ2251's Avatar
Just do it...
As I previously stated, it will work.
Most difficulty will be in mounting engine.
Keep driving chain as short as possible, meaning keep engine PTO as close as possible to pedal sprocket.
