Old 06-27-2019, 08:11 AM
Threeelectric Threeelectric is offline
Default Need help with gearing
I bought an old beat up yerf dog scout
No engine and all kinds of parts removed
Trying to fix it up for the kids but I want to haul stuff with it as well
I installed a predator 13hp, 40 series tc and a reverse gearbox transmission. It doesnít want to move lol and tc belt smokes
So I know I have a gearing problem
Iím pretty sure someone changed the axel sprocket before I got it
As itís a 42 tooth and welded on. The originals were bolted on.
They also put some old atv 22 inch tires on there
So 10 tooth drive 42 tooth axel 22 inch tires
Changing the axel sprocket is a no go but I could install a jack shaft
But what gears do I use to give this thing power not worried about speed
Old 06-27-2019, 08:41 AM
frostyflammable's Avatar
frostyflammable frostyflammable is offline
That is a very high gear ratio (1:4) with 22in tires. If my calculations are right with governor in tact 3600 RPM that is somewhere in the 55mph area. With 22in tires and a 40 series I would do at least a 1:6 ratio maybe even a tad more.
I am sure more knowledgeable people will chime in, but I believe that had a GY6 (or clone of it) so the variator and reverse gearbox had reductions.
Daniel
Old 06-27-2019, 08:59 AM
I'd do ~8/1 gear ratio with those huge tires. The Predator 420 helps, of course.
Currently Flathead-Crazed
Old 06-27-2019, 09:07 AM
When you say 8:1 how would I achieve this?
I have to use the 42t axel sprocket
Where can I find formulas for gearing when more than two gears are used?
Old 06-27-2019, 09:12 AM
mckutzy mckutzy is online now
Here is a calc...
Its pretty good for what you need now...
https://affordablegokarts.com/pages/...tio-calculator
Something about 10-20-10-42= 8.4:1
Let see some pic as to what you have and for space....
Old 06-27-2019, 09:17 AM
Why do you have to use the 42T sprocket?
Old 06-27-2019, 09:56 AM
Itís welded to the axel. Pretty hefty weld. I could grind it off but would rather not
Old 06-27-2019, 12:45 PM
It's either that or install a complicated jackshaft setup.
So you can pay something like ~$50 or more plus a lot of effort installing it.
I would definitely grind off the sprocket and pay ~$20 for a new sprocket.
Old 06-28-2019, 12:20 AM
landuse's Avatar
landuse landuse is offline
Originally Posted by mckutzy View Post
Here is a calc...
This is probably the way to go. If you have enough space for it all that is.
Post some pics
Old 06-28-2019, 08:50 AM
anderkart's Avatar
anderkart anderkart is offline
If you didn't want to install a jackshaft; another possible option would be to bolt an 80-tooth Split Sprocket to your 42-tooth axle sprocket.
You'd need to perfectly center the split sprockets before drilling the mounting holes in your old sprocket. This would effect your chain alignment, so you'd need to address that issue too.
80-tooth Split Sprockets are available in serveral different chain pitch sizes at this site:
http://gokartgalaxy.com/sprockets-an...cket-hubs.html
  #11
Old 06-30-2019, 04:48 PM
Jhoppe Jhoppe is offline
I'm with anderkart. One solution to the offset would be to weld another plate to the sprocket and then bolt a split sprocket to the new plate. Significantly more complicated, but probably not as much as a jackshaft setup.
  #12
Old 06-30-2019, 05:30 PM
Be easier to use the existing sprocket as a hub for the next one....
  #13
Old 06-30-2019, 05:33 PM
Originally Posted by Jhoppe View Post
...I'm anderkart....
Mmm hmmmmmmm.......
  #14
Old 07-01-2019, 02:47 AM
Originally Posted by JTSpeedDemon View Post
Mmm hmmmmmmm.......
I fixed it. Stupid phone lol
  #15
Old 07-01-2019, 07:31 AM
autocorrect!
Jhoppe (07-01-2019)
