Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Closed Thread
  #21
Old 07-15-2012, 11:01 PM
B man's Avatar
B man B man is offline
Tecumseh FTW!
Quote:
Originally Posted by Bluethunder3320 View Post
yeah my friends xr100 had a stamp like that
jimbo, oops, i thought it was a 9...
EDIT: doesnt work either way
Are those Zeros or O's ?
Also. it says it cant decode any VIN under 17 Digits.
"If your vehicle is older than 1981 or if your VIN number is less than 17 digits, our decoder is not be able to process it. "
If it doesn't work......well then its gonna!
  #22
Old 07-15-2012, 11:07 PM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
pretty sure they are zeros
i think its 17
  #23
Old 07-15-2012, 11:08 PM
B man's Avatar
Tecumseh FTW!
i think its 17
yeah it is. i counted wrong. oops.lol
  #24
Old 07-24-2012, 10:00 PM
workin on the bike some more. havent heard from my friend yet about splitting the cases. hopefully done soon but i cant complain hes doing it for free
the graphics were peeling in some spots, ripped and warped so i decided to just take them all off.
the tank plastic is faded, anybody know how to restore the color?
i noticed im going to need some seals. i think this part is just to keep dirt out, the brake works good still
hmm.... never seen the metal spring on the outside, i think we have a problem.
who puts stickers on the inside of fenders?
going to have to fix a stripped out thread on the clutch cover...
  #25
Old 07-25-2012, 02:33 PM
i got the cases back today.
rusty bearings, and seems like chunks of metal were scraping around the walls of the cases
you can see a chunk of metal jammed in between the rod and thrust washer here
  #26
Old 07-25-2012, 03:51 PM
brandongeiger2's Avatar
brandongeiger2 brandongeiger2 is offline
thats rough but here's a good thread repair kit that probably has the right size for the clutch cover its like a helicoil system. All Balls has a good countershaft seal kit and a crankshaft bearing/seal kit.
Are you rebuilding the top end? its only around 150 and as long as you've got it apart you may as well or atleast put a new ring(s)on
Dirt Devil Build http://www.diygokarts.com/vb/showthread.php?t=15085
"YOLO"-Carpe Diem for the uneducated
The Following User Says Thank You to brandongeiger2 For This Useful Post:
Bluethunder3320 (07-25-2012)
  #27
Old 07-25-2012, 04:03 PM
thats should work! thanks. the piston is a little discolored from heat so its going to be replaced too
i need so far...
motor mounts
shifter
piston
head
con rod
full gasket kit
tranny oil
exhaust springs
spark plug
crank bearings and seals
misc hardware
front shock seals and oil
a few more rubber parts
thread repair
radiator hoses
and of course 2 stroke fuel
the carb needs to be checked out and probably rebuilt
thats all i can think of now..
  #28
Old 07-25-2012, 04:34 PM
Are your fork seals leaking? its pretty easy to switch them out but not if you don't have a seal driver they can be a pain to get seated correctly without one...i just use a piece of pvc cut in half.
  #29
Old 07-25-2012, 07:45 PM
Quote:
i think they are leaking a little cause the shiny part is slightly wet with oil.
  #30
Old 07-25-2012, 08:02 PM
Oh well when you get to that point i can help you out with that or you can use youtube like I did haha there is no shortage of how-to videos on fork seal replacement its a fairly easy process just don't loose any small parts it seems the smaller the part the more important it is haha
  #31
Old 07-25-2012, 10:10 PM
fork seals are $30 at motorcycle superstore. also maybe i should change the oil since its lost some from leaking?
so youve done this? what brand did you get and what oil?
im going to start out at the core of this project and get a wiseco rod, $82, and all balls crank bearings/seals $41 so that i get free shipping.(over $100)
thats all the money i have yet..^
next its going to be athena complete gasket kit $39, Wiseco pro lite piston kit $105
then the rest of the parts are about $100
only thing i cant find is radiator hoses. the PO lost them all along with a bunch of hardware and motor mounts
  #32
Old 07-25-2012, 10:54 PM
stickers off, i cleaned all the fenders. the gas tank is sun faded but ill use the razor blade technique on that. scrape off the top layer of plastic, sand it with really fine grit, then use a heat gun (hair dryer in my case) to make it shiny
rear fender was painted, and it looked bad. so i began the very long process of scraping off all the paint with a razor blade.
this is how far i got tonight
  #33
Old 07-25-2012, 11:16 PM
bighead's Avatar
bighead bighead is offline
I used the razor and heatgun on my Brothers Ody. it turned out really good. Your scrapping away from you right?
Now you got your truck running have you thought about cutting and selling firewood?
Attention Criminals!! This is a defense free crime zone. All law-abiding citizens have been disarmed for your convenience.
  #34
Old 07-26-2012, 01:35 AM
neat idea, my neighbor has a ton of trees cut down and theyre just laying there on his lawn. maybe gotta ask. lol
unfortunately most people in my town dont have wood stoves. lots of big expensive houses.
yep i scrape away using the back side of the blade, takes forever and kills my fingers but ill get there
  #35
Old 07-26-2012, 02:40 AM
bighead's Avatar
Find a place you can cut legal wood from. Then place your add on CL for dilivered firewood. Tell them you will stack it for extra.
I got by with selling firewood for years when I was younger. Being in Oregon the demand was huge for it in the suburbs. Not to mention all the logging so lots to cut from.
Truck and trailer you can make some good money if you willing to work hard. Make a simle log splitter and rake in the cash.
I seen snow where you live. Sure people do not have stoves? What about the areas around you?
Oh yah I really dig the knobby tire on the rear. Looks mean. It should toss some good rocks and who ever is behind you.
The Following User Says Thank You to bighead For This Useful Post:
Bluethunder3320 (07-26-2012)
  #36
Old 07-26-2012, 06:58 AM
Here's where you can find your manual:
http://web.ebscohost.com/serrc/searc...&vid=3&hid=106
Username:Marshal
Passwordublic
Well do you have a yamaha dealership near you? they can tell you exactly how much oil you need and the type that was stock. As far as oil i use a different weight oil for my forks (10W) than stock because i built them specifically for my weight and riding style also they were sent in to be re-valved by race tech but the oil I use is called Maxima Racing Fork Fluid. Maxima is probably one of the best lubricant companies out there.
I would just buy a Wiseco Top End Kit it includes the wrist pin bearing, circlips, wrist pin, piston, rings, gaskets you know or a Pro X kit their pistons are cnc machined and the full kits are under $100.
Check out eBay for the hoses i found some here
  #37
Old 07-26-2012, 12:24 PM
i found the specs i need for the crank there! thanks!
the piston comes with everything but gaskets. which i dont need, because i need both top and bottom end gaskets
  #38
Old 07-26-2012, 12:43 PM
oh i get you...Wiseco makes some good pistons I'd go with the pro lite like you first said. That site is great It can be a little hard to find stuff in but it's got all the torque specs and overhaul guides the Clymer books have
  #39
Old 07-27-2012, 10:34 PM
today i fixed the radiator mount. looks like it had been broken for a while and it was loose rubbing the front fender.
a little crude but it will do the job. and i ran out of black spray paint so i just painted it with primer. you cant even see it under the fenders anyways.
then i noticed something wrong with the rear rim. why is there a bolt here?
and a hole here?
and a spoke missing...
i think maybe i should have left the rear fender as is. because now everything is white except for the front of the bike. it would be hard to strip paint off the plastic in front of the radiator especially.
hmm....
  #40
Old 07-27-2012, 10:48 PM
newrider3's Avatar
newrider3 newrider3 is offline
I believe the bolt is a balance thing, seen that on a ton of wheels.
Don't let your keyboard write checks that your a$$ can't cash.
The Following User Says Thank You to newrider3 For This Useful Post:
Bluethunder3320 (07-27-2012)
Closed Thread
