Closed Thread
Old 11-03-2018, 08:05 PM
propain37 propain37 is offline
Default Fuel
For a stock GX160, what fuel should I use? What octane rating?
Old 11-03-2018, 08:10 PM
anickode's Avatar
anickode anickode is offline
Regular unleaded pump gas is fine. 87 octane.
Ethanol free if you want to be real proper about it... But newer engines are designed to handle a small amount of ethanol better than they used to be.
In all likelihood, if you do find ethanol free gas, you won't find it below 90 octane.
"Well that would be a bomb."
The Following User Says Thank You to anickode For This Useful Post:
pearl111 (11-06-2018)
Old 11-03-2018, 09:25 PM
Kartorbust's Avatar
Kartorbust Kartorbust is offline
Overthinking Projects
If you do run 87 octane with 10% ethanol, I'd highly recommend that you mix some Seafoam or some fuel additive to help fend off tarnishing of the carburetor. Ethanol attracts moisture and it tends to gum up carbs even if they are made to run it safely.
Whatever I did, I DIDN'T do it!
The Following User Says Thank You to Kartorbust For This Useful Post:
Old 11-04-2018, 07:18 AM
Whitetrashrocker's Avatar
Whitetrashrocker Whitetrashrocker is offline
Odd.
The ethanol free around here is 87 octane.
Think for yourself, Question authority.
Old 11-04-2018, 08:06 AM
Kartorbust's Avatar
Quote:
Originally Posted by Whitetrashrocker View Post
Odd.
It could be a regional thing. By my dad's in Minnesota 89 and 91 are offered as non-oxygenated (ethanol free), here in Nebraska it could be 87, 89, or 91.
Old 11-04-2018, 08:29 AM
anickode's Avatar
Quote:
And here in Michigan, stations with ethanol-free gas are few and far between. At least by me anyway. Pretty much get your choice of Sunoco 90, 100, or 110.
  #7
Old 11-05-2018, 08:40 AM
65ShelbyClone's Avatar
65ShelbyClone 65ShelbyClone is offline
And here in CA, all on-highway gasoline has to be oxygenated with 10% ethanol by law.
Quote:
http://lmgtfy.com/?q=honda+gx160+owners+manual
If you're going to put additives in the gas, get one that actually does something useful like Sta-Bil. Not Lucas, not Marvel Mystery Oil, not STP, and certainly not Sea Foam.
Sea Foam is nothing but oil, naptha, and rubbing alcohol. That's straight from their original safety datasheet. They got sneaky on the newer one and now call the oil/naptha a "hydrocarbon blend" and "trade secret."
You really don't need any additives unless the engine is going to be stored for months with fuel in it. In that case a fuel preservative and draining the carb before storage will go a long way.
I'll show those guys who's in top place, I'll really give 'em a hotrod race.
  #8
Old 11-05-2018, 11:47 AM
Kartorbust's Avatar
Non-oxygenated is usually considered for motorcycles, boats, classic cars, small gas engines. Of course being that it's the People's Republic of California we're talking about here...I have no idea if their laws pretain to those classifications or not.
  #9
Old 11-05-2018, 04:00 PM
If the gasoline is for a vehicle that will be operated on (CA) public roads, it has to be E10. No exceptions. Even the 100 octane pump gas has to be. At the same time, if the fuel is not legal for road use, then it can't be dispensed out of a pump that fits in a regular filler neck.
All I can do is try to laugh and plan my escape.
Closed Thread
