Closed Thread
Old 09-28-2018, 02:19 PM
SquidBonez's Avatar
SquidBonez SquidBonez is offline
Default Predator 212 w/ Comet 30 Torque Specs?
How much torque is produced from a Predator 212 w/ a Comet 30 torque converter?
"You know I had to do it to 'em."
Old 09-28-2018, 03:24 PM
Tpdingo Tpdingo is offline
A crap ton of torque.
~24lbs at 3:1(7")
~18.5lbs at 2.3:1(6")
~8lbs at full open.
Also, depends if you have a 6" or 7" driven.
Give a wrench long enough and WD-40, and I can remove the world's rusty bolts.
Old 09-28-2018, 03:51 PM
anickode's Avatar
anickode anickode is offline
Quote:
~24lbs at 3:1(7")
~8lbs at full open.
Wrong, since the peak torque of the engine is not created at either engagement speed or at full speed.
That's why we use torque converters in the first place.
Plus you have to consider the inherent ~20% efficiency loss.
In reality, you'd need to do a Dyno pull with a completely stock setup to really pin down a full set of accurate numbers through the RPM range.
"Well that would be a bomb."
Old 09-28-2018, 03:56 PM
Well these are MAX torque ratings. If you were setting the motor to 2500RPM and for example, climbing a steep hill, it is very possible to get 24 out of the driven.
But yes, most of time time the numbers won't reach what I out out. Does it matter, no. Because Im too busy having fun with my 30T/C instead of worrying about numbers.
Closed Thread
