Go Back   DIY Go Kart Forum > Building Plans And Advice > Electric Projects
Reply
  #21
Old 03-29-2020, 03:36 PM
Shep1970 Shep1970 is online now
Not to rain on your parade.... but you should have put spacers under all 4 bolts not just on one side (sprocket side). Now how’s your chain alignment top/bottom front sprocket? If it’s not very near perfect you’ll eat through chains quickly if not throw chains very often.
Maybe it’s close enough but it looks like u raised it about 3/8 inch, the front sprocket must have a bad angle (not aligned to the rear)?
Just trying to help
Shep
  #22
Old 03-30-2020, 07:11 AM
mapoopsie mapoopsie is offline
Junior Member
Yeah Shep, you're right. I did actually have equal spacing on all four bolts when I tightened down the chain. The resulting damage to the motor mounts was a bending of the motor in to the mounting plate.
If you look at the first picture, you can see the motor is angled down towards the drive which is a result of the motor mounts collapsing.
So, to compensate for that, I had to re-mount spacing only the bolts closest to the drive sprocket. This seemed to work ok, but I have a feeling it won't last long. I think the long term fix is either a different mounting bracket (not sure if one is available for these BOMA motors, but if anyone knows of an L-shaped mount...send it my way) or a new motor since I don't think I can really bend the mounts back in to the factor position.
Reply
