Old 03-25-2020, 06:00 AM
frostyflammable's Avatar
frostyflammable frostyflammable is offline
Default Opinion... Stage 2 on Pred Hemi 212 or 196 Clone
Wanted to get opinions from everyone (dangerous on the internets I know) but I am getting ready to start a new project and will be doing a Stage 2 from GPS on an engine. I currently have a Predator 212 Hemi and a Hisun 196cc clone from a Coleman with a 3/4in shaft. I understand the Hemi will need some grinding but I am not worried about that. All my other project have some sort of Predator on them wanted to play with the Hisun 196cc clone just do not know much about them.
If you had both sitting around and both of them do work right now with no issues, would you build the Predator or Hisun, and why?
Finally for the cam, Mod2 or Hot cam? I am thinking Mod2 as it still has some torque down low but again never messed with a Hot 265 cam.
Thanks!
Old 03-25-2020, 08:22 AM
karl karl is offline
Most
Well then, I would rather build the hisun
The ARC rod is $15 cheaper, The crank should not need ground, normal cylinder head with full height springs. Regular flywheel taper.
For the cam, Mod2 for stock cylinder head and/or carb.
The mod2 is stock lift, the 265 is quite a bit more
The 265 Might not be good with the hemi head, or really not beneficial with stock valves/ airflow
Just my opinion , either way it should make some noise
The Following User Says Thank You to karl For This Useful Post:
Flyinhillbilly (03-26-2020)
Old 03-25-2020, 09:20 AM
Forgot to add, I will be putting a genuine Mikuni on... I want a flat-slide thinking maybe a 24mm.
Old 03-25-2020, 12:27 PM
KartFab's Avatar
KartFab KartFab is offline
I have seen 13.2 SAE horsepower with a MOD2 (add 20-40% to that number for inertia dynos) and a 22mm round-slide.
The problem with MOD2 is that it is a cheater cam (higher duration, stock lift) meant for cheating go karters. If you want to unlock more potential, it would be better to get a cam that has more lift, or go with some 1.3 ratio rockers on the mod2. Just my opinion here.
Old 03-25-2020, 04:53 PM
Hemiwoodworker Hemiwoodworker is offline
Was that with a 196 or 212 hemi?
Old 03-26-2020, 01:01 AM
KartFab's Avatar
212.
The 196 will make less.
The Following 2 Users Say Thank You to KartFab For This Useful Post:
Flyinhillbilly (03-26-2020), Jhoppe (03-26-2020)
Old 03-26-2020, 07:58 AM
Flyinhillbilly's Avatar
The great cornholio
212.
No replacement for dispalacement
The Following User Says Thank You to Flyinhillbilly For This Useful Post:
Jhoppe (03-26-2020)
