Old 02-19-2013, 06:16 PM
samirar samirar is offline
Default craigs list find
Hello I'm a newbie and I just got a go cart sunday for $125.00 with a 5hp briggs and stratton engine that was built in the 90s and it sat in a barn for 23 years. Sunday me and my friend went to go and look at the go cart after I talked to the guy about the go cart. Before I went to see the go cart I got a new spark plug and some starting fluid. and we got the guys house and me and my friend looked at the go cart and tested the compression and looked at the oil level and checked the gas tank and it had signs of sitting up a long time. and we took the old spark plug out and sprayed some starting fluid in there and put the new spark plug in and cranked the engine and it fired up for 3 seconds and died. and I bought the go cart. Then when I got home and took apart the carb and cleaned it out and one jet was clogged up and got the tank cleaned out put some new fuel in and drained the oil and put some fresh oil in and cranked it up and run and it needed it some carb adjustment to run right and I put a new chain on since the old one was stiff and frozen. and notice the clutch was shot. so I put a new one on and now the engine runs like a new one and drives a like a new go cart does
Old 02-19-2013, 06:22 PM
incogrhino incogrhino is offline
Pics?
Old 02-19-2013, 06:36 PM
I will get some more pics of it tomorrow
Old 02-19-2013, 06:41 PM
Doc Sprocket's Avatar
Carter Superwheels. I have one. Since mine was purchased as a bare frame, I'm interested to see the factory rearend setup.
Old 02-19-2013, 06:49 PM
toystory_4wdCarter Superwheels. I have one. Since mine was purchased as a bare frame, I'm interested to see the factory rearend setup.
I will get some pics of the factory rearend setup tomorrow
Old 02-19-2013, 07:09 PM
Thanks!
Old 02-20-2013, 12:57 AM
landuse's Avatar
landuse landuse is online now
Welcome to the forum. You scored on that kart. It always amazes me how hardy engines actually are. They can sit forever, and with just a little bit of maintenance you can get it running
Old 02-20-2013, 08:14 AM
cumminsbayou4x4's Avatar
cumminsbayou4x4 cumminsbayou4x4 is offline
yep thats a carter super wheels i have 2 seat i have had it since i was 4
Old 02-20-2013, 08:19 AM
jamyers's Avatar
jamyers jamyers is offline
GOOD for you - glad to see somebody taking the time/effort to bring an old engine back to life!!!
And WELCOME to the forum!
TexasTerror: http://www.diygokarts.com/vb/showthread.php?t=14872
Yerf-Dog: http://www.diygokarts.com/vb/showthread.php?t=19878
Old 02-20-2013, 09:19 AM
OzFab's Avatar
OzFab OzFab is offline
Good work, welcome to the forum
  #11
Old 02-20-2013, 07:48 PM
today my spark plug fouled out and when I was looking in where the spark plug goes in at there is some carbon build up and carbon in the exhaust port. should I be concerned about that?
  #12
Old 02-20-2013, 07:50 PM
It's normal, but it wouldn't hurt to clean it out if you are up to the task of pulling the cylinder head off.
  #13
Old 02-20-2013, 07:52 PM
I'm thinking about pulling it off tomorrow and cleaning it.
  #14
Old 02-20-2013, 08:02 PM
jamyers's Avatar
You might put the rear up on blocks so you can run the engine at high rpm, get a spray-bottle with water in it, and with the engine warmed up and running at high rpm, spritz water into the carb - a spray, not a stream - so it can flash to steam with the combustion and clean the carbon out. Don't shoot a bunch of liquid in there, don't want to hydro-lock the engine and murder it.
If you're not comfortable doing that, drizzle some atf into the carb, it'll do pretty much the same thing, plus make an impressive smokescreen.
  #15
Old 02-20-2013, 08:12 PM
cOw's Avatar
cOw cOw is offline
What is this atf that you mentioned?
Life consists not in holding good cards but in playing those you hold well. -Josh Billings \_(ツ)_/
  #16
Old 02-20-2013, 08:06 PM
do you think sea foam will work?
  #17
Old 02-20-2013, 10:42 PM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
i was thinking the same thing. i doubt it would hurt it. then you wouldn't have to buy new gaskets and it would save a lot of work
  #18
Old 02-20-2013, 08:16 PM
Automatic Transmission Fluid.
  #19
Old 02-22-2013, 06:40 AM
I have a question about the carburetor diaphragm. I have a old briggs carburetor that I cleaned and it haves the 4 bolts that holds the bowl on with the diaphragm and I put the newer type on it and it is getting way to much fuel and causing my spark plug to foul out and turn black and the tip. any suggestions?
  #20
Old 02-22-2013, 06:42 AM
landuse's Avatar
You have a pulse jet carb. What bowl are you talking about. Have you got a pic or two?
