Old 03-17-2007, 03:54 PM
rookie rookie is offline
Default help with sprocket
i have a old go cart put on a 5.5 ohv briggs motor on it now need help with the chain size.sprocket is a 72 teeth what size should chain be? 3/4 inch shaft HELP
Old 03-17-2007, 03:56 PM
any one out there please help
Old 03-17-2007, 07:17 PM
Kartmofo Kartmofo is offline
well rookie from the description i think u need a 35 pitch chain or a 41 pitch chain. Hope that helps.
Check out my site!
www.freewebs.com/machine_man
The Following User Says Thank You to Kartmofo For This Useful Post:
rookie (03-19-2007)
Old 03-17-2007, 10:34 PM
mikeandike mikeandike is offline
what's the distance between the teeth?
I believe if its 3/8" its a #35 pitch. If its 1/2" its a #40
The Following User Says Thank You to mikeandike For This Useful Post:
rookie (03-19-2007)
Old 03-18-2007, 01:01 PM
2or3wheels 2or3wheels is offline
If the parts supplyer u use is nice you could but both 35 and 40 and see which one fits. how fast do you want your cart to go? with 72 and the usual 12 tooth with 35 chain you going around 20 depending on your wheel diameter.
The Following User Says Thank You to 2or3wheels For This Useful Post:
rookie (03-19-2007)
