Old 10-30-2008, 04:35 PM
iwanttogofast iwanttogofast is offline
Default Front tire brakes
Im not even sure if i have ever seen a front brake on a go kart but i want it for spinning the tires. I would have to use a whole new hub and spindles. If the job is under 250$ im up for it. I don't want some red neck brakes either lol. I have had plenty of them in my day and very unreliable.
EDIT:Found same topic in another thread....should of used search.....
Old 10-30-2008, 07:53 PM
sayre315 sayre315 is offline
Rupp enduro
get some hydrolik discbrakes and make a braket where the caliper and the rotor are not atatched to anything but the spindal
Old 10-30-2008, 08:14 PM
umm...if the disc brake was attached to the spindle how would that stop it unless you had a live axel? it would have to be attached to the hub some how.
Old 10-31-2008, 11:02 AM
Rupp enduro
sorry thats what i ment
the rotor is atatched to the hub
the caliper has a braket so its either atatched to the hub or the spindal
Old 10-31-2008, 05:05 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
Spindles and con rods will need beefing up.
Old 11-01-2008, 03:46 PM
ya i was looking around and they have kits for them but they are salty. easier done would be to probably use 4 wheeler hubs and brake
