Closed Thread
Old 06-15-2018, 10:06 AM
rixardo rixardo is offline
Junior Member
Default Electric Start Switch
Has anyone here wired a switch from the electric start panel on a small engine somewhere other than the panel? How do you do it? I'm also planning to use a different switch, like a start button.
Old 06-15-2018, 10:10 AM
jandj's Avatar
jandj jandj is offline
Basically you just run a hot wire from whatever original source you have to one side of the switch and run a wire from the other side of the switch to wherever the original hot wire went to your starter solenoid.
Unless you have a multi wire setup with the small wires.
Then someone else will have to help you.
I don't want to be responsible for frying your wiring!
The Following User Says Thank You to jandj For This Useful Post:
gr8hairy1 (06-15-2018)
Old 06-15-2018, 10:35 AM
bob58o's Avatar
bob58o bob58o is offline
Sick, Tired, and in Debt
You should be able to find about 1000 videos on you tube.
People do this to their lawn tractors all the time.
Safety features like seat interlock devices are not for the serious mowers, so people like to rewire the whole thing.
The Following User Says Thank You to bob58o For This Useful Post:
Closed Thread
