Go Back   DIY Go Kart Forum > Build Contest > Build Off Contest Build Logs
Closed Thread
  #21
Old 06-24-2017, 01:25 PM
ond's Avatar
ond ond is offline
Been working on getting this front end mocked up, welded and working this morning. I got gussets made for the spindle steering arms, also outer axle braces made and welded on . Finished up the last steering arm and used heims joints instead of tie rod ends.
Oh yea a new bumper just in case !
The Following 3 Users Say Thank You to ond For This Useful Post:
ezcome-ezgo (06-26-2017), Functional Artist (06-29-2017), obone (06-27-2017)
  #22
Old 06-24-2017, 02:29 PM
tinamcjittles's Avatar
tinamcjittles tinamcjittles is offline
ello m8
QQ: why did you go with the steering assembly being in front of the kart? I haven't read through the first page yet but just wondering.
Just Google it.
  #23
Old 06-24-2017, 04:22 PM
ond's Avatar
ond ond is offline
I'm shooting for a vintage looking kart, a lot of the vintage racers had the steering in the front.
The Following User Says Thank You to ond For This Useful Post:
tinamcjittles (07-05-2017)
  #24
Old 06-26-2017, 08:07 PM
ond's Avatar
ond ond is offline
Ordered parts to put the rear end together with and I'm going with the live axle set up.
Wheels, bearings and hangers should be here before the weekend.
  #25
Old 06-26-2017, 08:41 PM
GearHeadGarage's Avatar
GearHeadGarage GearHeadGarage is offline
GearHeadGarage
  #26
Old 06-26-2017, 10:26 PM
chancer's Avatar
chancer chancer is offline
ɔ ɥ ɐ u ɔ ǝ ɹ
looking good
Why don't you, go back to your double wide and fry something!
  #27
Old 06-27-2017, 01:53 AM
6.5hp's Avatar
6.5hp 6.5hp is offline
man this looks nice
  #28
Old 06-27-2017, 06:52 AM
ond's Avatar
ond ond is offline
Quote:
Originally Posted by GearHeadGarage View Post
Quote:
Originally Posted by chancer View Post
looking good
Quote:
Originally Posted by 6.5hp View Post
man this looks nice
Thanks Guys !
  #29
Old 06-29-2017, 08:25 PM
ond's Avatar
ond ond is offline
I got parts in today just in time for the 4 day weekend.
Carlisle 11 x 6.00 - 5 Slick
ezcome-ezgo (06-30-2017)
  #30
Old 07-01-2017, 12:57 PM
ond's Avatar
ond ond is offline
Well the rear axle hangers were not long enough I had to extend them a 1''1/2 also boxed them in for a little added strength.
I used a piece of 1'' tubing to mock up the rear axle assembly. Now I can get some measurements for the real axle length, sprocket and brake system.
The Following 2 Users Say Thank You to ond For This Useful Post:
bob58o (07-04-2017), ezcome-ezgo (07-03-2017)
  #31
Old 07-01-2017, 01:57 PM
Functional Artist's Avatar
Functional Artist Functional Artist is offline
Aw,
I liked the tail pipes in the 4th to last pic.
Lookin' Good!
The Following User Says Thank You to Functional Artist For This Useful Post:
ond (07-03-2017)
  #32
Old 07-01-2017, 04:32 PM
ond's Avatar
ond ond is offline
Lol ...I never thought about tail pipes ! and Thanks
  #33
Old 07-03-2017, 12:37 AM
GearHeadGarage
I like it
The Following User Says Thank You to GearHeadGarage For This Useful Post:
ond (07-03-2017)
  #34
Old 07-03-2017, 05:51 PM
ond's Avatar
ond ond is offline
Off work today so I took advantage of it . Started working on the Predator 212 (60363) engine.
It will be mostly stock but has to look the part of a racing engine , but since my grand kids will be riding it to it will stay governed. I also like the throttle stop that the governor system gives you.
Started out by mounting and hooking up the fuel pump , drilled the hole in the valve cover on the top close to the exhaust valve side to get my pulse for the pump. Mounted the pump on a aluminum top plate that I had on hand.
Also Install a Robertson Torque tube header , just to make it look like a racing kart.....and yea a little more tone to !
bob58o (07-04-2017), ezcome-ezgo (07-05-2017), Functional Artist (07-03-2017)
  #35
Old 07-03-2017, 08:36 PM
Kansaskart Kansaskart is offline
That's purty!
The Following User Says Thank You to Kansaskart For This Useful Post:
ond (07-03-2017)
  #36
Old 07-04-2017, 02:37 AM
bob58o's Avatar
bob58o bob58o is online now
Sick, Tired, and in Debt
You don't have any issues running fuel pumps with the stock carbs and no return line?
I thought there were different needle/seats for gravity fed carbs vs pump fed carbs. A lot of people around here were using a return line from the pump back to the gas tank to lower the fuel pressure at the carb.
  #37
Old 07-04-2017, 08:20 AM
ond's Avatar
ond ond is offline
Can't say that I've ever ran in to that problem before , where I had to run a return line back to the tank . But who knows It might happen to this one...we'll see.
bob58o (07-04-2017)
  #38
Old 07-04-2017, 08:41 AM
Nicely layed out!
You gonna add a heat shield?
Seems kinda close.
ond (07-10-2017)
  #39
Old 07-04-2017, 08:48 AM
ond's Avatar
ond ond is offline
Thank You Sir ...and not for sure on a heat shield yet , but very possible !
  #40
Old 07-10-2017, 08:21 PM
GearHeadGarage
Love it, old school..
ond (07-10-2017)
Closed Thread
