Closed Thread
Old 03-19-2019, 02:43 PM
vidaliaman vidaliaman is offline
Junior Member
Default wheel bolt pattern
what bolt pattern is this considered? the old rims were 11" in diameter
thanks bunch!!!
Old 03-19-2019, 02:56 PM
txluke txluke is offline
Looks like a 4x4
Old 03-20-2019, 07:30 AM
Junior Member
thanks txluke, the old rims were 11" diameter but they drilled new holes in them to match the bolt pattern, where does someone go to purchase new rear rims and tires?
Old 03-20-2019, 07:58 AM
ezcome-ezgo's Avatar
If it's a 4x4 pattern, golf cart wheels will fit. These are readily available. Also, trailer wheels use this pattern if you're looking for a taller, narrower wheel.
Old 03-20-2019, 09:44 AM
Junior Member
thanks for the info!!!
Closed Thread
