  #161
Old 08-22-2018, 08:05 PM
Functional Artist's Avatar
Hopefully this second one goes that smoothly
Step 1.)
I melted (2) more solder blobs
...where the Lima bean was mounted
Step 2.)
I gripped the second jumper with a clamp
…pressed (1) end of it to (1) of the solder blobs
…& then, used the soldering iron to solder them together
Step 3.)
I pressed the other end of the jumper to the second blob
…& soldered them together too
Boom!, I think we did it
Now, I just gotta reinstall this yellow wire
…& put the ends back on
RESISTANCE IS FUTILE
  #162
Old 08-23-2018, 08:43 AM
Lets "fire this thing up" & see if it works
Took 'er out to the bike, plugged the AC input plug into an extension cord & turned the switch on
The red & green lights lit up
…& No Magic Smoke
Before connecting it to the bike, I flipped the balance monitor on to get an initial voltage reading
...43V is showing on the Tri-Quad
…& 21.6V is showing on both of the balance monitors
Then, I plugged the DC output plug into the charge port on the bike
…& both red lights, on the charger, lit up
Now, lets see how long this takes
…& to what voltage the battery pack gets charged back up to
  #163
Old 08-24-2018, 01:32 PM
I recorded the voltage of the battery pack before starting
mulit-meter: 43V
balance monitor: 21.6V / 21.6V
I connected the Yewi UY-600 charger @ 4:45pm
...both red lights lit up but, the fan was not on
I didn't want to turn the circuit breaker on, to get a reading from the Tri-Quad
...or keep messing with the MM
...so, I just took hourly voltage readings from the balance monitor
1 hour 5:45pm 22.8V / 22.8V 2 red lights & yes the fan is on
2 hours 6:45pm 23.8 V/ 23.8V 2 red lights & yes the fan is on
3 hours 7:45pm 24.3V / 24.3V 2 red lights & no the fan is off
4 hours 8:45pm 24.4V / 24.4V 2 red lights & no the fan is off
5 hours 9:45 pm 24.4V / 24.4V 1 red light & 1 green light & no fan
Unhooked the charger, turned the circuit breaker on
...& got 49.7V from the Tri-Quad
Hmmm, it should be topped off @ 49V (but, who knows how accurate these Chinese meters are?)
So, I waited an hour & took more readings (rested voltage)
6 hours ~11:00 pm
Tri-Quad: 49.7V
Balance monitor: 24.4V / 24.4V
The next morning I took some more readings (overnight rested voltage)
16 hours ~9:00am
Tri-Quad: 49.8V
Balance monitor: 24.4V / 24.4V (48.8V total)
Multi-meter: 50.6V
Wow!, (3) different Chinese meters with (3) different readings
  #164
Old 08-27-2018, 10:00 AM
Design flaw:
I can't really see the Amp/Volt meter too good while riding
...the digits are too small
…& it's angled down a little, too "flat" also
That's what R & D is all about
The next Tri-Quad (or what ever meter I come up with)
...will have bigger digits (like the ones on the Balance Monitor)
…& be angled back a little bit too
I want to see what this thing is doing
...but, its kinda hard to watch the meters & drive/ride
So, to gather some data, I set up the camera, to record the dash board, while I took a little ride
I also finally got the historical license plate in the mail
I folded the registration up (expiration date 2050)
...put it in the plastic bag from the BMV that the plate came in (to protect it, I need it to last a long time)
...& tucked it under the "papers protector flap" under the seat
Gettin' closer to bein' legal
landuse (08-28-2018)
  #165
Old 08-28-2018, 12:17 AM
landuse's Avatar
landuse landuse is offline
Very cool
Functional Artist (08-28-2018)
  #166
Old 08-29-2018, 07:56 AM
That ride was fun, after reviewing the data, it looks like the voltage sag was usually ~1V but, also I saw ~2V drop several times too
If you look closely @ ~3:00, I saw the Amps hit ~500A
I didn't do top speed or "really long pulls" yet
I am kinda taking my time
I am still getting a "feel" for her
I set up the camera & did some more testing, after charging, of course
  #167
Old 08-31-2018, 07:33 AM
Everything seems to be working well.
I am kinda surprised about the 500A readings
...running thru a 150A circuit breaker
…& it not triggering
I have checked the temp (by hand) several times
…but, it was never (even) warm to the touch
So, I guess were OK
...I'll still keep an eye on it
The top speed seems to be right at 35 MPH
...which is ...Kool!
...it moves right along
...& the amp draw @ top speed seemed to only be ~20 - 30A on average
Here is more "good" data
