Go Back   DIY Go Kart Forum > Other Stuff > Off Topic Forum
Closed Thread
Old 07-20-2008, 03:48 PM
oscaryu1 oscaryu1 is offline
Default ARC Billet Flywheel for Clone = $100 and more!
http://www.dynocamstore.com/index.ph...sort=3a&page=1
HEAVEN!
Old 07-20-2008, 05:11 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
Well box stock (except a flywheel) clone is now a WKA class so its picking up popularity.
Old 07-20-2008, 05:17 PM
Been readin up some threads at 4cycle eh? :p
But $100! You save $50 if you buy there too! Their filter adapters are dirt cheap, ect...
Old 07-20-2008, 05:44 PM
sayre315 sayre315 is offline
Rupp enduro
any body ever shoped there
i dont like buying from places i never heard about
Old 07-20-2008, 07:36 PM
Dyno Cams?! They pretty make most of the cams out there! AGK carries their $50 .265" lift cam.
Quote:
This is a .265" lift Dyno cam. This cam is designed for use with larger than stock carburetors. Duration is 236 on the intake and 236 on the exhaust. No block clearance needed for this cam. Drop in and go! This is our best bang for the buck, top choice.
I've gotten a cam from ARC, but they said they had to send it back to Dyno cams due to a incorrect grind. Got my cam, very pleased with it.
Closed Thread
