Closed Thread
Old 05-02-2013, 02:19 PM
Jblankster's Avatar
Jblankster Jblankster is offline
Default V twin vs 6hp built vs big block stock
So I'm debating the idea of running a Briggs or Honda v twin over a single piston now after I saw something interesting.
Vtwin look at dimensions and weight
http://www.vanguardengines.com/engin...-hp-v-twin-hs/
Single look at dimensions and weight
http://www.vanguardengines.com/engin...oss-hp-single/
Same hp, the vtwin is actually more compact AND only 1 pound more.
Now a 6hp
It's 30 pounds less and when built it can make the same power.
Here's my pickle. If I'm turning a motor I need more ccs so a big block or vtwin would be an advantage to me.
But those who are looking at a big block single should consider a vtwin.
Old 05-06-2013, 12:41 AM
DJEEPER DJEEPER is offline
6hp will turn higher RPM quicker because of lower rotating mass and such. The V-twin will spin slower but have butt loads of low end torque.
All of this is arbitrary once you start doing mods.
My Vtwin pushes a 5:1 all day long and pushes my 22" rear tires/heavy cart up past 50mph.
Its all depending on what you want to do with it.
Closed Thread
