Closed Thread
Old 02-24-2013, 09:46 AM
voided voided is offline
parking lot pimp
Default Noob with experience building a shifter kart. Kx125 style
I'm gonna update this along the way as my build thread, as I stated in my introduction thread I've lurked for a while and now that I got my big purchases out if the way I'm gonna start tear down and rebuild..
I was sapposed to have a kx250 motor but with further inspection the motor cases were cracked beyond repair for a budget build so I opted for a kx125 my buddies towing company had.
This kx 125 is in rough shape but was much better for the parts I need, except a kickstarter, its stripped. ( planning on push starting while I can find a replacement for a good deal as the motor still runs strong..
The kart frame from what I can gather is a coyote as its the only one that looks like mine for front spindles.
The kart currently has a clone motor, and motor mount I plan on altering to adapt the kx motor to my frame. The karts brakes work great and the frame rolls smoothly and axle or spindles does not seem to be bent or slightly off balance. I will need some newer tires in the near future. I will also need a seat for my large a**
I will be conquering the tear down of both today, mocking up and taking measurements.
As my garage sits now...
Old 02-24-2013, 09:51 AM
parking lot pimp
Sorry mods I deff just put this in the wrong sub forum...
Old 02-24-2013, 06:29 PM
parking lot pimp
pretty productive day...
one of the first pictures you can see why it had to be a kawasaki...
i kept it pretty simple, tear down and take measurements. opted for the no kickstart to make room for me to be able to sit comfortably.
the mount looks easier then i expected.
DEA6BDE2-DF7A-4E43-8950-18C0B89FAD67-2954-000001A2ECC68296_zps76970107.jpg   34211257-C6C0-4F2D-B3B8-D193397F456A-2954-000001A31A82E81D_zps6e1ab01b.jpg
BA0DA186-F914-4687-8478-E5FE05D3AA36-2954-000001A326FE1C40_zps029a5ce3.jpg   090CFC0D-1D17-4648-AAF6-02F4A6C2B3AC-2954-000001A2FCAAA6F4_zpsd6aa4547.jpg
495AB945-C39E-4BD2-8533-B96B93FE8947-2954-000001A313235058_zps0a98f12b.jpg   918D7D5A-D16D-49C4-9E72-6B4C56BDA064-2954-000001A33588D7DC_zpse521fe8a.jpg
Old 02-24-2013, 07:30 PM
OzFab's Avatar
OzFab OzFab is offline
Quote:
What's stripped, the kick or the shaft?
Kawasaki's are great machines if you don't mind paying for them...
You seem to be doing well, keep up the good work
Old 02-24-2013, 08:19 PM
parking lot pimp
fabroman: the kickstart doesnt always catch.
ive had quite a few kawi's... in that picture is my 2000 zx12, girls 2010 ninja 250, kx125 (parts bike) and the jetski is a supercharged kawi.
Old 02-24-2013, 09:20 PM
DS13's Avatar
DS13 DS13 is offline
Annoying the Neighbors!!!
You are doing exactly what I'm doing haha
Two wrongs may not make a right but three lefts will
http://www.diygokarts.com/vb/showthread.php?t=16543
  #7
Old 02-25-2013, 05:30 AM
parking lot pimp
Ds13: what's your plans for fueling and gearing..
Ill gladly post pics and measurements for my motor mount once completed
  #8
Old 02-25-2013, 09:21 AM
DS13's Avatar
well im using the gas tank off the 125 and mounting it behind the drivers seat above the carb because it is gravity fed. Right now the gearing is about 4:1 which is the same as on the bike (iirc).
  #9
Old 02-26-2013, 08:43 PM
doggerss doggerss is offline
Voided what year is the kx250 motor with the cra ked cases I got a motor myself Im doing up to put on my margay but some of the internals are missing many in the trans.
  #10
Old 02-26-2013, 08:51 PM
parking lot pimp
Doggerss : ill see if it is still available, since I didn't want it and it was broken I'm not sure if the tow company disposed of it yet.
As for a update, I've got my metal stock to build my motor mount and will be doing so tomorrow. Trying to keep as much space possible for me, since I'm 6'4" and 250..
Also ordered my shifter handle as it was only 20 bux on eBay and now I just need the clutch handle for a reasonable price.
  #11
Old 02-26-2013, 10:22 PM
Ted Hamilton's Avatar
Ted Hamilton Ted Hamilton is offline
Vintage Kart Afficionado
Checkout the www.apskarting.com site's closeout area for a clutch handle -- AMC brand, iirc....
  #12
Old 02-27-2013, 06:17 AM
Nodroz's Avatar
Nodroz Nodroz is offline
Looking good so far! Keep up the good work.
  #13
Old 02-27-2013, 06:47 AM
parking lot pimp
Ted Hamilton : thanks ill take a look
Nodroz : if I had a welder it would go much quicker. Just not trying to hack it together..
Should have the motor mount together tomorrow.
May end up making a clutch handle.. As the complete handle I want is $90 and just the physical handle without the cable stop/ collar is only $20 I feel I can make the cable stop easily..
  #14
Old 02-27-2013, 09:47 AM
Sinbad001 Sinbad001 is offline
I know this is a go kart forum but I also love dirt bikes. Why do so many people wreck dirt bikes to power karts? If the bike is crashed, bent forks, frame, wheels, fine. But to take apart a runner, or near runner, hurts. If anyone in Michigan is going to do this call me first, I will get you an engine to trade for that dirt bike. Whew, rant over. I have an 01 ZX12R also in green.
  #15
Old 02-27-2013, 01:56 PM
irunktm irunktm is offline
Junior Member
because even if the bike is rideable it can need alot of work and the bike is not worth it. The Kx 125 he is taking the motor from, it looks like a mid 90's in pretty beat shape, is maybe worth $600-$700, but all the bearings can be toast, it can need a new chain and sprockets, ect. its not worth fixing back up and shifter karts are a f***ing blast. I built one with a bored out cr500 last summer. and also, you can make a custom clutch lever using a bike's clutch perch, that what i did and it works great and cost alot less than buying one. i can post a pic of what i did if you want to see it.
  #16
Old 02-27-2013, 04:34 PM
parking lot pimp
Sinbad001: I feel the same way... But this bike on another hand can not be sold as a complete bike. In ct where I live we have a problem with dirtbikes running the streets and have many fatalities from dirtbike accidents.. The tow company that sold me the bike only sold it to me as a parts bike and I have to return the frame to them. I cannot sell the frame by any means.. Everything on it is mine tho. So I'm parting it out.
  #17
Old 02-27-2013, 07:01 PM
Well those rules would really make it easier to swallow. Good luck with the build.
  #18
Old 02-27-2013, 07:16 PM
parking lot pimp
well as a update i managed to get my motor mounts pieces cut.
i started with some flat stock and some square tubing as its easier for my to stack for height
i will be welding this tomorrow, but taped them together to see how my measurements were.
in one picture shows my raw metals.
in another picture i shows placement on the motor. once i have them welded together i will bolt them to the motor and square the mounts out then weld in the bars that will connect the front mount to rear mount
08EF0948-D47C-48FE-8A64-BDEA08B4E683-6844-0000039D22165C45_zps1937a30f.jpg   4F20ABFE-B38A-47C4-853E-8E5327F5025E-6844-0000039D307AC16E_zpsbff0ac61.jpg
70599D69-B35E-4B88-9B9B-76B5F1EF7AA0-6844-0000039D0977CD28_zpseb9b0c32.jpg   649B883A-3A6B-4E71-A4D7-63613BBBA5F2-6844-0000039CFF901538_zps27de95b5.jpg
  #19
Old 02-27-2013, 07:20 PM
parking lot pimp
i know stuff may look crooked but its all measured and square, i just need to clean them up and weld them tomorrow.
so far this mount has only cost me $20 for steel, bolts, washers, bolts, and safety pins.
i safety pin anything i build even with nylon nuts just so i dont loose anything
  #20
Old 02-27-2013, 07:26 PM
parking lot pimp
here's the 12 that sits under the sheet.
Sinbad001: its a 2000 with a a slight overbore and re-ring, bear mixed stack, pc3, stepped tube hindle shortened can, shocks/forks revalved and built for my weight, and stretched 9" with under-bracing.
Closed Thread
