Reply
Old 03-30-2020, 10:03 PM
TxTrigger TxTrigger is offline
Junior Member
Default ID Please
If anyone could ID this go cart for me it would be much appreciated. Bought it used for my son but it kept throwing the chain while he was riding it. Looking closer the bearing on the sprocket side is completely gone.
Old 03-30-2020, 10:42 PM
Smerft85 Smerft85 is offline
Murray, but I don't know the model, looks like my explorer but with full suspension up front. Should be a 1" axle and bearings are reasonably priced, check out Amazon, gopowersports.com, Ebay, BMIkarts.com, or let google be your guide. Welcome to the forum!
The Following User Says Thank You to Smerft85 For This Useful Post:
TxTrigger (03-31-2020)
Old 03-30-2020, 10:56 PM
Junior Member
Thanks for your help Smerft85!!
Old 03-31-2020, 08:06 AM
JTSpeedDemon's Avatar
2019 Build Off Winner!
Looks like a Murray Kilowatt to me.
Currently Flathead-Crazed
The Following User Says Thank You to JTSpeedDemon For This Useful Post:
Smerft85 (03-31-2020)
Old 03-31-2020, 08:29 AM
Quote:
That's what I was leaning toward as well, but didn't wanna jump the gun.
---------- Post added at 08:29 AM ---------- Previous post was at 08:28 AM ----------
Quote:
No problem at all, hope you get it going correctly. Those Murray's are pretty beefy frames and worth the effort.
Old 03-31-2020, 12:10 PM
KartFab's Avatar
KartFab KartFab is offline
also most go karts use standard bearings. The two most common bearing sizes are 5/8"id x 1 3/8" od for driven units of torque converters, jackshafts, and front wheel bearings.
Rear axle bearings are almost always 1" ID bearings.
There are exceptions to all of this as well.
Beyond this, if you run into carburetor issues, you can replace the stock carb with a bolt on PZ22 carb and drill out the main carb jet to .033" for good sucess on performance. You can also drop in a pair of 18-19 lb briggs animal springs on it to prevent valve float.I wouldnt look into performance upgrades on that engine unless it has a steel camshaft. Some of the OHH tecumseh engines i have seen have had a camshaft made entirely of plastic.
Free Go Kart Plans https://kartfab.com Go Kart Videos https://www.youtube.com/c/KartFab
  #7
Old 03-31-2020, 03:23 PM
Solomonster212's Avatar
Solomonster212 Solomonster212 is offline
High Compression Member
That's a Murray Explorer for sure. No doubt.
Simply springs were added.
I do karting on the side... And cars on the other side... And --- wait, how many sides do I have?
  #8
Old 03-31-2020, 07:31 PM
Might just be why it looks just like my explorer!
  #9
Old 04-01-2020, 12:04 AM
Junior Member
So being a newbie to go carts they seem pretty simple. So my son an I are pretty much tearing everything apart and rebuilding rebuilding it the correct way (the previous owner took a lot of shortcuts with it) so we're going to take our time and do it right. The 6.5hp on it now is not too bad (does the job) but as always looking for more torque and hp with a reliable motor. What motor(s) are recommend that could feed the need per say?
  #10
Old 04-01-2020, 02:56 AM
landuse's Avatar
landuse landuse is offline
I would stick with what you got and just do a few small performance mods. Like a stage 1 kit
  #11
Old 04-01-2020, 08:00 AM
Wilson_Engine_Shop's Avatar
Wilson_Engine_Shop Wilson_Engine_Shop is offline
Supporter
Looks like a cross between my Kilowatt and my Explorer. I dig it. Is that a tecumseh on it?
Build it. Run it. Break it. Repeat
The Following User Says Thank You to Wilson_Engine_Shop For This Useful Post:
Solomonster212 (04-01-2020)
  #12
Old 04-01-2020, 08:07 AM
Jhoppe Jhoppe is offline
Having toyed with the tecumseh OHV the things I had luck with, carburetor upgrade and shave the head.
The issue you run into with carbs for these is not many people make an adapter. So your options are to drill out the hole that are there to fit whatever you get, or fabricate an adapter yourself.
We had good luck shaving the head on the murrays we had as kids as well. Made a noticeable difference. You could look into a thinner head gasket as well. We used stock gasket and mild shave by taping sandpaper to an old window to keep things flat.
The Following User Says Thank You to Jhoppe For This Useful Post:
TxTrigger (04-01-2020)
Reply
