Go Back   DIY Go Kart Forum > Build Contest > Build Off Contest Build Logs
Closed Thread
  #141
Old 03-09-2019, 04:47 PM
pa17315 pa17315 is offline
Default 2019 Hydraulic brake master cylinder part 4
I have finally fabricate a mount for the motorcycle master cylinder. It is bolted onto existing location. If it doesn't work, then I will just go back to the previous master cylinder.
  #142
Old 03-09-2019, 04:57 PM
Default 2019 Hydraulic brake master cylinder part 5
Master cylinder mounted.
Brake hydraulic switch connected.
Brake light works when emergency brake is activated or brake pedal is pressed.
Brake line needs to be bleed to rid air
  #143
Old 03-09-2019, 05:08 PM
Default 2019 Front wheel hub part 1
There is a problem with my front wheel hub. The bearing is busted.
Spec calls for 4x4 wheel hub which was purchased from BMI kart.
4 x 4 Heavy Duty Wheel Hub (Front with 5/8" Bearing)
Part Number:K260056
I am not quite sure what has caused the bearing to bust. Could have been me.
When it was installed, I have made sure the wheel hub rotates freely. It was not installed too tight nor loose_just the right amount. Maybe, it was too much stress on the hub due to testing.
Anyway, here are some pics who is thinking of using the same hub.
  #144
Old 03-09-2019, 05:14 PM
Default 2019 Front wheel hub part 2
Found replacement bearing on Amazon.
Next issue, how to remove and replace bearing.
Bang it out or buy a press from Harbor freight.
Or build one myself. It seems easy enough and beside, I can build with better steel.
  #145
Old 03-10-2019, 10:17 AM
Default 2019 Front wheel hub part 3
I am replacing the front wheel hub with this item:
"4 x4 Plated Steel Wheel Hub with Taper Roller Bearing - 5/8" ID".
It looks like it may last longer than previous option.
The Following User Says Thank You to pa17315 For This Useful Post:
ezcome-ezgo (03-11-2019)
  #146
Old 03-11-2019, 07:08 AM
ezcome-ezgo's Avatar
Nice choice.
  #147
Old 03-11-2019, 02:43 PM
Default 2019 Front wheel hub part 4
Item received.
There are 5/8 inch bushings which goes in the bearing to accommodate the 5/8" spindle. That may pose a problem because it may not stay in place. It moves freely and may not remain on the bearing.
I cut a 5/8" DOM pipe to fit in between the two bushings.
  #148
Old 03-11-2019, 02:45 PM
Default 2019 Front wheel hub part 5
Installation
  #149
Old 03-12-2019, 12:10 PM
Default 2019 brake bleeding jig
Rigged up something to bleed the brake by yourself.
Just push and hold the lever to activate the brake, release the brake valve, close the valve and release the lever.
  #150
Old 03-14-2019, 01:53 AM
Denny Denny is offline
Do not put a spacer between tapered roller bearings. Preload should be set with the spindle nut.
Old 03-14-2019, 06:29 AM
Quote:
Thanks,
I wasn't sure about that.
  #152
Old 03-15-2019, 12:19 AM
Glad I could help! What kind of rear tires are those and where did you get them and how much did they cost?
Old 03-17-2019, 12:12 PM
Tires were bought from Amazon for $100.00
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Rims were also from Amazon. (2) for 18.00
Note: These tires are great off road, grass and or mud, however on the street, there are too much drag.
Denny (03-18-2019)
  #154
Old 03-20-2019, 10:54 AM
Default 2019 Front wheel hub part 6
On previous post, I was using the 5/8" spindle and I just feel uneasy with the movable bushing inside new hub.
I have decided to buy new spindle from OMB warehouse "Spindle Only, 3/4-16 Axle X 4-1/2" Length, 5/8" Kingpin, Side #1, Nylon Inserts"
It is a lot smoother than the other ones that I have installed.
Enclosed are the failed bearings. Too much friction has worn down the side thin wall on the bearing.
  #155
Old 03-20-2019, 11:12 AM
Default 2019 Go Kart overall update
As I have wrapped up the go kart, there are some final pics of the go kart as finished stage.
Hopefully, all major updates has been addressed. Murphy's law would probably dictate future issues. For now, it is time for serious test drives.
I will update issues as it comes up.
  #156
Old 03-20-2019, 11:49 AM
tgus3's Avatar
tgus3 tgus3 is offline
a member
Wow that's real slick
good job
Only know you love it when you let it go..
  #157
Old 03-20-2019, 02:39 PM
Quote:
good job
Thanks.
Started in August 2018 and now almost the end of March 2019. A little more than 7 months. I would have never guessed that it would have taken this long or how intensive the build.
Along the way, I have deviated from original plan and result were better looking. If I have sticked to original plan, I would have finished earlier. However, the result would have been your typical go kart. With the changes, the go kart fits me and I am satisfied with the result.
I would have to recommend to all and any newbie to go ahead and go for it. It is definitely worth the trip.
  #158
Old 03-22-2019, 10:52 AM
Default 2019-Predator Engine Choke
Predator Engine choke
Has anyone rig up a system where you can operate the predator choke from driver seat location?
I want to devise someway to operate the choke up front without running back to turn off the choke each time the engine has warm up. This may be useful when you are already in the driver seat. In another word, I may be lazy and want to have every control within reaching distance.
Thanks
  #159
Old 03-22-2019, 08:35 PM
Go to NAPA and buy a choke cable for a fork lift or something long like that.
Old 04-06-2019, 11:51 PM
Default 2019-Predator Engine Remote Choke part 1
Wouldn't it be nice to operate the predator choke at other location?
Since I have relocated the electrical start to the dash, turning the choke lever on and off is a pain. I have searched and have not found a solution for predator engine with manual choke.
The next few posts will be about remote choke for predator engine or a possible option for engine with manual choke.
Closed Thread
