Closed Thread
Old 03-16-2018, 07:15 PM
Teerone Teerone is offline
Junior Member
Default Torque Converter
Hey Everybody,
I am trying to remove this part of the torque converter. Any suggestions on the best way to get it off. I want to replace it after painting the dinosaur.
684DFB10-2764-4FF7-9348-192B4F3CB9D5.jpg   191877C3-E5CB-4D86-96EE-1523D28B0922.jpg
Old 03-16-2018, 07:39 PM
jmandawg jmandawg is offline
Pic is not that good, Is that silver piece screwed on (2nd pic)? Looks like you can take a crescent wrench and unscrew it.
The Following User Says Thank You to jmandawg For This Useful Post:
Teerone (03-19-2018)
Old 03-16-2018, 07:52 PM
Junior Member
Here is another pick. There is a snap ring & my small basic tool cant get it off. Also. It looks like a key insert is there.
Old 03-16-2018, 07:53 PM
If the silver part doesn't unbolt try to remove the snap ring under it, then it might slide off, that's my best guess, there are guys on here that should know exactly how to remove it. Might want to wait for them.
Old 03-16-2018, 07:57 PM
mckutzy mckutzy is online now
Should be able to carefully pry the snap ring off with a flat head screw driver.... Just make sure you wear safety glasses... It'll take your eye out for sure...
The Following 2 Users Say Thank You to mckutzy For This Useful Post:
Randy H (03-16-2018), Teerone (03-19-2018)
Old 03-16-2018, 08:05 PM
Junior Member
Thanks for the info, it may be tomorrow before I get back at it.
  #7
Old 03-16-2018, 11:17 PM
Whitetrashrocker's Avatar
Whitetrashrocker Whitetrashrocker is offline
How about taking the nut off the other side and sliding the whole axle out?
Think for yourself, Question authority.
The Following User Says Thank You to Whitetrashrocker For This Useful Post:
  #8
Old 03-17-2018, 06:48 AM
bob58o's Avatar
bob58o bob58o is offline
Assistant to the Manager
I was going to stay to get snap ring pliers, but the snap ring doesn't hold the driven unit on, does it? It just holds the driven unit together, right?
There are two types of people. Those who can extrapolate from incomplete data
The Following User Says Thank You to bob58o For This Useful Post:
  #9
Old 03-17-2018, 07:40 AM
itsid's Avatar
itsid itsid is offline
WHAT?
he wants to remove the driven pulley, not disassemble it..
penetrating oil and a rubber mallet and it'll be off the shaft within just a few days of patiently waiting for the oil to soak in
PS in case I'm wrong and you ant to disassemble it..
reattach a nut and release the snap ring, that way the cam doesn't jump off.
take care at reassmbling since the spring needs to be preloaded correctly.
  #10
Old 03-17-2018, 08:45 AM
Junior Member
Yes, I just want to remove the whole assembly-its old abd worn. I will replace it with a new one. The bolt will not slide out so I may try the penetrating oil & mallet
---------- Post added at 09:45 AM ---------- Previous post was at 09:02 AM ----------
I assume its operable. I am now curious if I can find a replacement part if I do remoce it.
  #11
Old 03-17-2018, 09:34 AM
itsid's Avatar
old and worn is correct; but it can surely be revived with a bit of elbow grease
(better than a new one IMHO!)
Anyways, sure replacements can be found at mfgsupply.com for example
https://www.mfgsupply.com/gomini/gom...q30driven.html
you'd also find the replacement parts there if you need some:
https://www.mfgsupply.com/gomini/gom...ivenparts.html
just saying
PS good penetrating oil (NOT ordinary WD40!! but pb blaster or WD40 specialist penetrant)
some mild heat from a heat gun to speed things up
and if you get impatient,
some tapping with a mallet against the face of the jackshaft,
if all you have is a hammer, reengage a nut a few threads to prevent the shaft from mushrooming out or ruining the threads.
No violence though
  #12
Old 03-17-2018, 11:07 AM
Junior Member
Thanks so much for all of the helpful info.
  #13
Old 03-17-2018, 11:54 AM
Panhead5496's Avatar
Panhead5496 Panhead5496 is offline
If you can get it off, you might could get a brand new set from eBay for about $60 shipped. It would be all of it: both pulleys, backplate, and belt. Just a suggestion
The Following User Says Thank You to Panhead5496 For This Useful Post:
Closed Thread
