Closed Thread
Old 08-01-2017, 03:55 PM
Teerone Teerone is offline
Junior Member
Default Manco brakes
Hello,
I have a Manco kart, I believe its a 415-10 model. My issue is the brake band doesnt close/tighten enough to stop the kart. I have tried a 4 inch band but it seemed too small. I currently have a 5 inch band on it. Please help, any advice is greatly appreciated.
Old 08-01-2017, 04:38 PM
KartFab's Avatar
KartFab KartFab is offline
Try the 4" band again, but adjust what it is connected to. I don't have x ray vision but the brake rod sure does look like it has space for another hole at the pedal end.
Free Go Kart Plans https://kartfab.com Go Kart Videos https://www.youtube.com/c/KartFab
The Following User Says Thank You to KartFab For This Useful Post:
Teerone (08-01-2017)
Old 08-01-2017, 09:38 PM
Junior Member
I tried the 4 inch band and still no go. The brake drum I have is a 4 inch-as far as I know, that's the normal size. I know this is not suppose to be "this hard." I've ordered a brake cable wire to try another option.
Any other suggestions?
Old 08-01-2017, 09:42 PM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
Flip the brake band over so it is shorter on top (where the rod is attached).
Rods are a better brake actuator.
I see you're a brave guy (or gal), tempting fate with those Harbor Freight dolly wheel/tire combos.
I can admire that.
Old 08-01-2017, 10:36 PM
Junior Member
Hellion,
Thanks for the suggestion & for the record I am a guy. I've had the "bigger" karts with suspension & thought I wanted something a bit smaller. This kart was a roller when I bought it and thought it would be cool for me to ride. I quickly noticed that was not the case so it turned into a sale item. Please forgive me for the front tires- this is intended to sale to a younger individual with the predator engine tuned down.
Old 08-02-2017, 03:19 AM
itsid's Avatar
itsid itsid is offline
do not sell HF dolly wheels to a kid.. that's attempted murder! (exaggeration for a reason)
These things are meant for 2mph without ANY load and will not withstand any more than that for longer than a minute and a half.
(short: it'll fail on the test ride)
sometimes you really get what you paid for
Now, there are 4.5 brake bands; if all else fails try one of those
http://www.bmikarts.com/45-Brake-Band-_p_542.html
WeddingRing (08-03-2017)
  #7
Old 08-03-2017, 09:53 AM
Karttekk Karttekk is offline
Zoom in on this illustration to see if your band is connected similar to the one pictured. The 4" band looks to be the correct one. Hope this helps.
Thanks
The Following User Says Thank You to Karttekk For This Useful Post:
Closed Thread
