Old 03-24-2018, 06:00 PM
Teerone Teerone is offline
Default Bolt will not budge
Trying to remove the bottom bolt from the shock. The other one came out with a tap of the hammer. I have sprayed PB Blaster and banged the heck out of it & still not budging. Any suggestion?
Old 03-24-2018, 06:08 PM
Whitetrashrocker's Avatar
Whitetrashrocker Whitetrashrocker is offline
Looks like it could be in a bind. Can you un thread it?
The Following User Says Thank You to Whitetrashrocker For This Useful Post:
Teerone (03-24-2018)
Old 03-24-2018, 06:09 PM
mckutzy mckutzy is online now
Try unscrewing and tapping the end with a soft hammer at the same time....
Old 03-24-2018, 06:18 PM
I havent tried to unthread it.
---------- Post added at 07:18 PM ---------- Previous post was at 07:12 PM ----------
I tried unscrewing with the tapping & no go.
Old 03-24-2018, 06:39 PM
anickode's Avatar
anickode anickode is offline
The bolt could have a saddle worn in it... Will it turn, or is it totally seized?
The Following User Says Thank You to anickode For This Useful Post:
Old 03-24-2018, 06:50 PM
Might try a C-clamp with a deep throat socket......
Press on the threaded side, use the socket with a bit bigger than the head of the bolt....
See if that moves it...
Old 03-24-2018, 06:52 PM
Karttekk Karttekk is offline
If the other one came out by tapping on it, put a nut on the end of the bolt to protect the threads then give it a decent whack with a fairly large hammer. It should break loose.
The Following 2 Users Say Thank You to Karttekk For This Useful Post:
scatteredsun (03-27-2018), Teerone (03-24-2018)
Old 03-24-2018, 07:09 PM
It will turn
Old 03-24-2018, 08:14 PM
If the other one came out by tapping on it, this one should come out the same way. I don't think one is threaded and the other isn't although it could be. Soak it overnight then whack it with a nut on the end of the bolt. You'll be fine. It's just being stubborn.
Old 03-24-2018, 09:14 PM
Finally. I picked up & held the frond end while banging the bot-it finally came out. I guess the weight (resting on the tire as a stand) was causing the issue. Thanks everyone for there ideas & help. I really appreciate it.
The Following User Says Thank You to Teerone For This Useful Post:
Panhead5496 (03-24-2018)
  #11
Old 03-25-2018, 09:57 AM
There was never a doubt!
  #12
Old 03-26-2018, 07:05 PM
TT540 TT540 is offline
Newb
The weight was it. Like the other guy said above, the bolt had worn a saddle and it needed the preload off to get it out. Next time, unbolt the top of the shock first. I have the same kart. Is your steering worn as well?
The Following User Says Thank You to TT540 For This Useful Post:
Teerone (03-30-2018)
  #13
Old 03-26-2018, 07:18 PM
2SlickNick's Avatar
2SlickNick 2SlickNick is offline
American Minibikes @ FB
I had a similar experience with a yerf dog bolt... I made the video to show me getting it free but... ended up cutting it off and ordering a new A-arm LOl...
https://www.youtube.com/user/dirtyinaz
The Following 2 Users Say Thank You to 2SlickNick For This Useful Post:
ezcome-ezgo (03-27-2018), jmandawg (03-27-2018)
  #14
Old 03-27-2018, 12:54 PM
jmandawg jmandawg is offline
LOL i've been there many times before...
  #15
Old 03-30-2018, 06:56 PM
Yes, the steering is anbit worn on this one.
