  #41
Old 12-09-2017, 09:12 PM
Adultlife's Avatar
Adultlife Adultlife is offline
Originally Posted by OzFab View Post
That should work
Drove it in the back yard which is pretty steep and wooded, feels like a torque monster , Iím afraid it will be slow.. all was well until the axle chain shot off itís master link somehow.. more parts yay
The Following User Says Thank You to Adultlife For This Useful Post:
gr8hairy1 (12-10-2017)
  #42
Old 12-09-2017, 09:49 PM
OzFab's Avatar
OzFab OzFab is offline
Originally Posted by Adultlife View Post
Drove it in the back yard which is pretty steep and wooded, feels like a torque monster , I’m afraid it will be slow..
My kart is a "torque monster" but, it still does 30+mph...
That may be a result of perfect gearing, engine mods or a combination of the two...
all was well until the axle chain shot off it’s master link somehow.. more parts yay
That's why I'm, not a fan of master links; if a chain is gonna break, it will; why give it a reason?
Having said that, are you absolutely positive it was installed correctly?
The Following User Says Thank You to OzFab For This Useful Post:
gr8hairy1 (12-14-2017)
  #43
Old 12-13-2017, 02:54 PM
Adultlife's Avatar
Help! The chain started slipping on the sprocket, and yes it was very taut. I lost about 3 master links , and finally the drive chain snapped one of itíslinks open. The link came apart in like a Y shape. It is a type #41 should that happen ?? Should I go back to the huge type 50?
  #44
Old 12-13-2017, 06:33 PM
OzFab's Avatar
#41 or just #4X?
#41 is the smallest & weakest of all the #4X series chains; #40 is around 50% stronger, not to mention 1/8" wider; if you have #41 chain on a #40 or #428 sprocket, the chain will be grabbing on the sprocket, causing the breakages...
The Following 2 Users Say Thank You to OzFab For This Useful Post:
gr8hairy1 (12-14-2017), Nosandwich (12-14-2017)
  #45
Old 12-14-2017, 07:39 AM
Adultlife's Avatar
#41 or just #4X?
Sprocket and chain are supposed to both be #41 , i assumed it was stronger than the 40. Iím upgrading to the #50 sprocket and 530 chain. Yay more parts ..
  #46
Old 12-14-2017, 06:25 PM
gr8hairy1 gr8hairy1 is offline
The sprockets may be fine. Maybe try a 420 chain. That's the setup I'm going with.
41 chains are usually rated at 2,000lbs. 420 chains are almost double that at 3,700lbs. I got a heavy duty 420 that is supposed to be 4,000lbs.
It depends on your budget I suppose.
The Following User Says Thank You to gr8hairy1 For This Useful Post:
bob58o (12-14-2017)
  #47
Old 12-14-2017, 09:19 PM
bob58o's Avatar
bob58o bob58o is offline
Assistant to the Manager
This may be a dumb question. How do you cut a chain to fit and install it without a master link?
There are two types of people. Those who can extrapolate from incomplete data
The Following User Says Thank You to bob58o For This Useful Post:
  #48
Old 12-14-2017, 09:51 PM
mckutzy mckutzy is online now
I use this by performance tool...
  #49
Old 12-14-2017, 10:35 PM
Adultlife's Avatar
Will 420 chain work with the #41 sprockets ? If so thatís worth a try
gr8hairy1 (12-15-2017)
  #50
Old 12-14-2017, 10:47 PM
bob58o's Avatar
#420 chain works fine on #41 sprockets.
---------- Post added at 11:47 PM ---------- Previous post was at 11:44 PM ----------
Does that allow you reuse the pin and then re-rivet? Or do you use a new pin?
I've only used that type of tool for breaking the chain, then I've always used a master link. My tool is more basic than that one.
  #51
Old 12-14-2017, 10:53 PM
Adultlife's Avatar
How bout the 420 chain was twice as much as the 50 I had priced out.. oh well , ordered it. Got to be about $1100 deep in this project now
  #52
Old 12-14-2017, 11:04 PM
bob58o's Avatar
How much you pay? I think I normally order 10' with a few master links for ~$20 shipped.
It is at least two chains worth.
https://www.ebay.com/itm/420-1R-ROLL...4AAOxyFjNSQwaZ
$18
I have heard good things about O-Ring chain, but never used it.
https://www.ebay.com/itm/KAWASAKI-KX...JWY0F1&vxp=mtr
  #53
Old 12-15-2017, 06:38 AM
Bob- From what I have gathered you can reuse the previous pin. With that being said, depends on the chain itself, some have a peen on the rivets from the factory, some don't. The tool however can re-peen over an edge via the one punch tool it has.
Me personally... I use the master link to join... I have enough issues when I have to do a break down...
The Following 2 Users Say Thank You to mckutzy For This Useful Post:
bob58o (12-15-2017), gr8hairy1 (12-15-2017)
  #54
Old 01-27-2018, 05:18 PM
Adultlife's Avatar
Default Been a minute
Adding some underneath protection and added a tensioner to one chain, still want one for the other
D862ADE1-ECF6-40ED-9BA4-B8FD290E1204.jpg   E7AB3A83-72ED-4808-8874-48301B161E89.jpg
  #55
Old 01-27-2018, 06:04 PM
I bet the motor will be running really great, now you've flipped it on the end...
  #56
Old 02-02-2018, 04:47 PM
Adultlife's Avatar
Default 90% done
Needs bigger tank and custom exhaust !
3C864D5A-56BB-49FE-B794-47D5EA82561C.jpg   C9B0679A-EE11-4780-A8A8-CC63AF95B33A.jpg
The Following 2 Users Say Thank You to Adultlife For This Useful Post:
ezcome-ezgo (02-05-2018), gr8hairy1 (02-02-2018)
  #57
Old 02-02-2018, 11:31 PM
Adultlife's Avatar
This wonít be quiet
The Following 3 Users Say Thank You to Adultlife For This Useful Post:
ezcome-ezgo (02-05-2018), gr8hairy1 (02-03-2018), landuse (02-04-2018)
  #58
Old 02-06-2018, 12:34 PM
Fink343 Fink343 is offline
You have an awesome Buggy Adultlife
The Following User Says Thank You to Fink343 For This Useful Post:
Adultlife (02-06-2018)
  #59
Old 02-06-2018, 04:15 PM
65ShelbyClone's Avatar
65ShelbyClone 65ShelbyClone is offline
Originally Posted by bob58o View Post
Does that [chain breaker] allow you reuse the pin and then re-rivet? Or do you use a new pin?
Nothing is reused; you install a special master link with pins that can be staked.
O-ring chain is pretty much standard equipment for offroad non-MX motorcycles. It lasts longer in very dirty conditions, but has a lot more drag and can't really be cleaned.
