Go Back   DIY Go Kart Forum > Building Plans And Advice > All Other Parts
Closed Thread
Old 05-19-2012, 02:33 PM
Britcom61 Britcom61 is offline
Junior Member
Default Help Finding 8x7 YerfDog Rear Rim
My 32001 has the rear wheel rim coming appart from the hub, it is an 8x7 size wheel with 18x8.5x8 size tire. I just need the rim, have looked online at tractor supply, Northern Tool etc but have had no luck. Anyone know where I can get a replacement? Help would be greatly appreciated....
Old 05-19-2012, 04:07 PM
rcarteraz07 rcarteraz07 is offline
Bmikarts.com. The stock replacement parts for yerf dogs.
Old 05-19-2012, 08:37 PM
Slash4 Slash4 is offline
gokartsupply.com
FYI: 8" actually slowed mine down alot on acceleration and top speed. There are decent on/off road 6" tires.
Old 05-19-2012, 09:08 PM
Junior Member
My rim has "8x7.00 G.B.C. 1008" stamped on it, the tire size is 18x8.50-8.
Would this be the correct rim? I found this at BMI
8" Rim w/1" Bore (260081)
This is an 8" rim
1" Bore with 1/4" Keyway
Rim is 7" wide
The Following User Says Thank You to Britcom61 For This Useful Post:
countryboy9104 (11-22-2012)
Old 11-22-2012, 06:57 PM
countryboy9104 countryboy9104 is offline
Junior Member
Default Thanks!
The same exact thing happened to my Yerf-Dog go kart and I just wanted to say thank you for having the solution!
Closed Thread
