Old 05-16-2012, 03:09 PM
rcarteraz07 rcarteraz07 is offline
Default Yerf Dog 3203 Torque Converter
Hello... So one of yerf dog bodies I bought came with the torque converter too. Pretty sweet for only $50. Problem I have is the piece that goes in the engine shaft is in pieces and I can't seem to figure it out. Anyone have a manual fr this? It's a comet torque converter. Thanks all!
Old 05-16-2012, 07:18 PM
augidog augidog is offline
comet 30-series driver...part #9 isn't applicable after 1995...otherwise this outta do it. the small bushing/spacer in your pic goes on the shaft before you put the pulley on.
Old 05-16-2012, 09:09 PM
Awesome! Thank you so much for this! I'm going to try putting it together tomorrow. Do you know what the max HP rating for these are? Is it 9hp?
Old 05-17-2012, 01:16 AM
landuse's Avatar
landuse landuse is offline
The reating is 8HP. If you look at the top left of the literature for this TC you will see the 8HP rating. You should be able to get away with your 9HP though. The TC's are somewhat overengineered
