Old 05-14-2012, 01:44 PM
rcarteraz07 rcarteraz07 is offline
Default Help! Changing front tire!
Hey, I need some help. I can't seem to figure out how to change the front tires on my go kart. They split rim design with three bolts. I've removed the bolts but the rim won't come apart. Do I need undo this nut on here? Thanks
Old 05-14-2012, 01:46 PM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
you do need to remove the nut. after that, the halfs might be a little stuck from just being pressed together for so long, but it should come right apart
Old 05-14-2012, 01:55 PM
Okay... Would the bearings be okay if I spray some break free or wd40 on it cuz it's not budging.
Old 05-14-2012, 02:02 PM
qtband's Avatar
qtband qtband is offline
Should be fine. Grease them up before you re-install them.
I asked God for a go-kart, but God doesn't work that way. So I stole one and asked for forgiveness.
Old 05-14-2012, 03:25 PM
Thanks for the help. Got them both changed!
Old 05-15-2012, 07:46 AM
qtband's Avatar
Great! Now go and wear them out!
