Reply
Old 01-26-2020, 10:43 AM
Zaza Zaza is offline
Junior Member
Default Put rim without bearing
Is it possible to put a rim on screw without bearing?
Old 01-26-2020, 11:09 AM
itsid's Avatar
itsid itsid is offline
if you want to bolt it to a wall ... of course!
Old 01-26-2020, 11:15 AM
Junior Member
Quote:
I canít find correct diameter for the bearing and screw
Because that I want to know if i can put the rim without bearing and using
Old 01-26-2020, 01:08 PM
jmaack jmaack is offline
sure you can then you will be hunting alot more replacement parts than a bearing
Old 01-26-2020, 01:57 PM
J.S.@SMS's Avatar
J.S.@SMS J.S.@SMS is offline
Road Hazard
Why do I get the feeling that the rim is off a lawnmower. Those run bushings instead of bearings. And that's fine at 5mph, but when you get into the mid teens or twenties they won't last long, if they even last at all.
For his personal safety, keep this one away from bicycles.
Old 01-26-2020, 03:53 PM
mckutzy mckutzy is offline
If you run it like that it will potentially weld itself to the bolt... It needs some bushings, and hubs that have a grease nipple..
  #7
Old 01-26-2020, 10:43 PM
Smerft85 Smerft85 is offline
Looks like lawn mower wheels to me, see if the bushings will knock out of the hub, I had to use a flanged bearing to get wheels like that to work, cheap on Amazon.
  #8
Old 01-27-2020, 01:13 AM
Junior Member
Quote:
Do you link please?
  #9
Old 01-27-2020, 07:34 AM
Not sure what size you need, is that a 5/8" axle? You'll also need the inner diameter of the hub itself after the bushings are removed (if it's removable bushings). Do you have a micrometer?
Reply
