Old 08-13-2019, 06:37 PM
Ltcjc Ltcjc is offline
Default B/S 5 hp blowing oil thru the Carb
Hey guys, my grandson was ripping thru the yard in the Red B/S cart (5 hp) and came to a stop when the engine died. I saw oil leaking from the area of the carb. Any thoughts or opinions? Other than possibly sloshing the oil around during hard turns, I can't think of why oil would leak from the carb. Thanks in advance.
Old 08-14-2019, 12:01 AM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
Have you verified the engine isn’t over-full of oil?
If it is, the excess oil usually finds it’s way out of the engine. If it’s not, it sounds like a lot of blow-by (from worn piston rings, worn valve guides etc) making its way out of the engine via the crankcase breather tube. The breather could be malfunctioning or in need of a cleaning.
Sorry, I’m drawing a big blank on your “red B/S cart”.
Old 08-14-2019, 05:43 AM
BigWes's Avatar
BigWes BigWes is online now
Possible that the float is sticking leading to excess fuel getting in the crankcase. This can also be related to your symptoms as well as a stuck crankcase vent.
Old 08-14-2019, 09:00 AM
B/S cart = Briggs and Stratton cart, sorry. I'll check the oil level, and breather. Thanks
Old 08-14-2019, 09:19 AM
Dingocat's Avatar
Dingocat Dingocat is online now
Broke
I think they wanted a pic....
Current Manco hoarder
Old 08-14-2019, 11:34 AM
BigWes's Avatar
Not me...
Old 08-14-2019, 01:05 PM
Currently flathead-crazed
If you have oil(make sure it's OIL, not gas) leaking from the intake port, you may have a major problem. Are you sure it's not coming from the breather area? It may be as simple as getting a new breather valve assembly(I know https://www.dynocams.com/ has them).
As they said, you may simply be overfull. I filled my Briggs 5 208 all the way, and for a little while, it was leaking from the sidecover area, but eventually stopped. If you have a YouTube channel, please record a video of the problem and share it here. Or lots of detailed pictures.
Local Bird Engineering Nut
Old 08-15-2019, 03:41 AM
Hellion's Avatar
I didn’t necessarily want a pic, or one of the cart (kart) per se, but one of the engine and your issue would’ve helped.
Still not sure what engine you have (guessing it’s an OHV Briggs/Intek), but the problem/solution applies to nearly every small engine of the kind we deal with here.
The Following User Says Thank You to Hellion For This Useful Post:
mckutzy (08-15-2019)
