Old 08-04-2012, 01:24 PM
CGaul CGaul is offline
Mini Dwarf Newbee
Default Adjusting mechanical shock
I was curious about the how to adjust a mechanical shock. There seems to be a collar that could twist and lock into a new position, but I'm not sure of the best way to do this. Is it a matter of simply musceling the spring to a compressed position then moving, or is there a better way? I attached a photo of where the adjustment on the spring seems to be. Thanks!
Old 08-04-2012, 03:33 PM
realfast89gt's Avatar
realfast89gt realfast89gt is offline
Kart Krazy!!
You simply turn the bottom part that the spring is sitting on(silver piece). It is easier if there is no weight on the spring, like when it isnt installed like in the picture. I have adjusted mine with the weight of the kart on them, with a large set of pliers, but they do sell a tool made for it. It should turn fairly easy, so i dont think the tool is needed.
Old 08-04-2012, 04:46 PM
Mini Dwarf Newbee
It's not installed as it sits right now. So do you hold one end, like with a vice or even a screw driver then use a wrench to turn the other?
Old 08-04-2012, 05:29 PM
anderkart's Avatar
anderkart anderkart is offline
Yep, you could clamp the very bottom in a vice and the turn the part at the bottom of the spring. Looks like your spring is adjusted to the softest setting now.
Here' what the correct tool looks like:
______________________
_____________________________
The Following User Says Thank You to anderkart For This Useful Post:
CGaul (08-05-2012)
Old 08-05-2012, 06:31 PM
Mini Dwarf Newbee
Where would one find one of those? I've been trying to search for google but haven't seem to have found the right group of words to desribe it correctly
Old 08-05-2012, 06:47 PM
Fabroman's Avatar
Fabroman Fabroman is offline
There appears to be a hole in the side of the adjuster; could you insert a small metal bar into it to use as leverage?
There's no better feeling than seeing something you made work
Nothing is impossible to fix if you have enough time, money & patience
Old 08-05-2012, 09:06 PM
brandongeiger2's Avatar
brandongeiger2 brandongeiger2 is offline
You wouldn't use a spanner for that it just looks like a bar slides into the side there and turns it like fabro said... it you want you could use a strut press to compress the spring and allow the preload adjuster to move but thats more work than necessary.
Dirt Devil Build http://www.diygokarts.com/vb/showthread.php?t=15085
"YOLO"-Carpe Diem for the uneducated
Old 08-16-2012, 10:33 AM
Chud Chud is offline
What type and size is that shock that you have posted? Because I have the same type and wanted to know more info on it.
Thanks!
-Chud-
Old 08-16-2012, 11:19 AM
anderkart's Avatar
There's several different styles made to fit different shocks:
You might find some for sale at motorcycle shops, or you could search for one avalible online by researching
this google search link:--> http://www.google.com/search?q=tool+...w=1024&bih=556
Old 08-26-2012, 09:15 AM
spyder1968's Avatar
spyder1968 spyder1968 is offline
these can usually be easily adjusted with a decent sized pair of channel lock pliers. just wrap a rag around the adjuster first so you don't scratch it all up.
http://charliesgokartstuff.wordpress.com
SEMPER FI
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
