Go Back   DIY Go Kart Forum > Build Contest > Build Off Contest Main Area
  #21
Old 11-20-2019, 02:39 PM
Joe-405's Avatar
Joe-405 Joe-405 is offline
2018 Buildoff Winner ! 😎😎
I wasn’t gonna enter it this year. Was just wanting to place it somewhere since all is asking what my new toy is. But I’ve had one before and I was always curious if it fit or not.
  #22
Old 11-28-2019, 07:18 PM
4WDKarts 4WDKarts is offline
4WD Karts
Ok, I'm going for this year's title with our 5th generation 4WD Kart. It will be done and painted with testing video by the end of this year. More pics are to come through the whole build process.
Thanks
I'll get my photos in soon with required doc.
  #23
Old 12-01-2019, 12:47 AM
Joe-405's Avatar
Thanks
Iím guessing you wonít qualify. Itís gonna be too close to being done by the time you post the password and attached picture of said kart.
  #24
Old 12-01-2019, 05:10 PM
Silentstuget Silentstuget is offline
Default New member wants in
Ok new to site, and I think this has inspired me to pull out the old tomberlin and slap a new motor in the old girl! ... yep I'm in! I'll start posting tomorrow
  #25
Old 12-01-2019, 05:18 PM
Currently flathead-crazed
4WDKarts & Silentstuget,
Not to burst your bubble, but one of the requirements is that the project can't be more than 50% done at time of entry. So it may not work out. Sorry!
King of Controversy
  #26
Old 12-02-2019, 09:09 PM
robertdjung's Avatar
robertdjung robertdjung is offline
Administrator
Originally Posted by J.S.@SMS View Post
How about a car trans, driveshaft and axle in a kart with a body? I'm asking for next year or the year after, not this one.
A car transmission in a go kart? Sketch it up and let's take a look. Don't forget to estimate weight, and material for frame. Should be interesting if nothing else to see this sketch.
---------- Post added at 09:09 PM ---------- Previous post was at 09:08 PM ----------
Originally Posted by Joe-405 View Post
So does a Sandrail count with a 4 cylinder car engine ? I donít see where itís not as it is a dune buggy based machine.
Just curious..........Iím probably gonna put in the build log section or other builds.
If you build it, post it.
The Following User Says Thank You to robertdjung For This Useful Post:
Joe-405 (12-03-2019)
  #27
Old 12-03-2019, 06:49 AM
J.S.@SMS's Avatar
J.S.@SMS J.S.@SMS is online now
Here 8am-? Mon-Fri
I'm not at all good with sketches, so I'll try to describe it the best I can (should be easier than trying to read scribbly lines and stick figures). I'm going to make a custom frame and chassis, with a body. It'll be moved by a mildly built predator 670 with a 4 speed manual transmission attached to it. That'll be turning a custom (aka homemade) driveshaft, and a shortened axle, with cheap wheels and smaller of road tires. (I'll work on a sketch using paint). With the size I'm going for, it'll look like it's lifted with huge tires, even though it'll be the stock height of most pickups, and only have 225 (or 235) 75 r15's on it
I just spent all that time typing that up, and I realized, I could have just said I'm building a minicar, or more of a mini suv/truck. Will it still be allowed if I run full street lights and get it street legal?
PS: One hint, Scout. I'll let you figure it out.
  #28
Old 12-03-2019, 08:59 AM
J.S.@SMS's Avatar
Here 8am-? Mon-Fri
Hopefully this uploads ok.
Name:	scout plans.png
So red is the engine, grey is the clutch (it will me an automotive clutch), green is the transmission, tan is the axle and driveshaft, black is the rear leaf spring, and blue is the chassis (I'm thinking 2x3 rectangular tubing and 1 or 1 1/2" tubing for the frame). The engine and trans will be tilted back slightly, but paint won't do that.
I'm going to try to keep this thing under 1,000 pounds (shooting for 750). But I've checked with kartcalc and it seems to think that in 4th gear it'll be able to cruise at 60mph while turning 3600rpm (stock max) even if it weighs 1500. I will build the engine to around 30hp maybe a little more, and hopefully 6k-6500 max rpm. And I'll run an alternator (performance 670 makes one for this engine), so I can have a battery and full lights.
  #29
Old 12-03-2019, 09:43 AM
Budget GoKart's Avatar
Aka a kenbar
i could model it with some parts from a video game and my own custom parts j.s
edit: boom!
  #30
Old 12-03-2019, 03:19 PM
J.S.@SMS's Avatar
Here 8am-? Mon-Fri
Dang, Thanks dude, I don't think I could do that in a million years (I'm not good with computers). How long did that take.
So pretty much that with a truck body, all in maybe 5/8 to 3/4 scale.
  #31
Old 12-03-2019, 05:29 PM
Aka a kenbar
Took like 20 min not a big deal I can model any ideas for you just pm me
  #32
Old 12-03-2019, 11:32 PM
Administrator
Hm. Your build may suffer without actually some plans. Best of luck, we look forward to seeing it. Move this discussion to a build thread, please, if it's going to continue.
