Go Back   DIY Go Kart Forum > Other Stuff > More Builds
Closed Thread
Old 07-17-2018, 10:48 AM
Kyle_ Kyle_ is offline
Junior Member
Default Future racing lawnmower. I canít start it...
A family friend has been finding junk laying around and found me a law tractor type thing with a 8hp vertical shaft on it and it doesnít have pull start just electric. I donít really want my hands torn off so Iíd like to have the electric start working unfortunately the wiring was all chewed up by rodents. This is my first lawnmower and I donít know much about electric starting systems but I think it is a 6v system. If anyone has any advice or anything it would be nice.
The Following User Says Thank You to Kyle_ For This Useful Post:
ezcome-ezgo (07-24-2018)
Old 07-17-2018, 12:12 PM
mckutzy mckutzy is offline
Test it with a set of batt cables... Just touch the terminals to see if it turns over...
Old 07-18-2018, 01:27 AM
landuse's Avatar
landuse landuse is offline
Post a few pics of the engine so that we know what it is. Make, model?
Old 07-20-2018, 10:08 PM
Kansaskart Kansaskart is offline
Best thing to do is rip out all the wiring and make your own I do it often. Order a toggle and push button start. Maybe a new solonoid. It's most likely 12v it's tractors that need converted not lawnmowers.
It's easy and you'll learn a lot. The engine itself is very easy, it's all the other stuff like safeties etc that start turning the wiring into a rats nest. The engine will run independent, only thing it needs is turn the starter wired and turned over. It only has a hot wire the battery grounds to the frame. You do need that switch though lol. If it's a Briggs it will have a black ground that goes to your toggle. Then 2 wires for charging. Be easier to watch a vid. The guy in Fearlessfront explains all this and makes it easy. Just keep in mind the hot wire from the battery to the starter and the battery ground both have to be heavy gauge wires otherwise your wiring will spontaneous combust lol. All fine and dandy till the gas goes next then you have a fireball in your yard and it burns to a nice rusty color. Needless to say I've seen it happen lol.
https://www.google.com/search?client...10.0bShQAmJ_fE
---------- Post added at 10:08 PM ---------- Previous post was at 10:06 PM ----------
The fearless front vid is the first one, it's good. That guy builds really cool stuff.
Closed Thread
