Old 03-05-2019, 08:37 AM
Currently flathead-crazed
Default Are turf tires good on pavement?
I have 13x5x6 tubeless tires on the back of my go kart, but before I actually need to replace them as they're fine now, I want to know if turf tires will work on various terrains.
I know the John and Ike from CarsandCameras used turf tires on their rat rod wagon eventually, but they didn't say much else about how they perform.
Local Bird Engineering Nut
Old 03-05-2019, 11:46 AM
itsid's Avatar
itsid itsid is online now
turf savers are usually a bit softer than 'std' road tyres
so they wear down a bit quicker but on the other hand they prrovide a tad more grip too.
also some are less 'rigid' (4ply vs 6 ply or more)
gives you a softer ride but don't like to get hammered around corners as much..
for a yard kart that is used as such, turf savers are fine IMHO,
and the cushioned ride is nicer for less than perfect roads too..
if you are -as your name suggests- about to hit a few speed limits however,
then you might not be very happy with them being soft and wearing quickly.
But (know the bad news..)
that being a typical Mower size.. you are very likely not going to find true road tyres that size easily.
Some scooter tyres maybe but the round profile doesn't work well on a kart;
maybe a race slick or two...
but beyond that it gets thin I'd say.
Old 03-05-2019, 12:08 PM
I'm thinkin' turfs'll be fine for putting around the yard and some stock pavement runs, but chances are I'll just try to find something else instead.
---------- Post added at 01:08 PM ---------- Previous post was at 12:59 PM ----------
Mmm, found these at BMIKarts:
https://www.bmikarts.com/13-x-500-6-...re_p_4054.html
https://www.bmikarts.com/13-x-500-6C...re_p_4055.html
What does the C mean on the size? I think it means commercial, or basically heavy duty.
OMBWarehouse has these:
https://www.ombwarehouse.com/13-x-50...-carlisle.html
And a similar one in 2-ply.
So I guess there are treaded non turf tires out there in my size.
So, the more plies a tire has, the longer it will last but it will be harder?
Old 03-05-2019, 12:50 PM
Kartorbust's Avatar
To me Turf savers are an oxymoron. They seem to do more damage to a yard in my experience.
