Old 12-04-2012, 04:24 PM
cOw's Avatar
cOw cOw is offline
Default Clutch Issue
My clutches outer housing is very loose. How do I fix it.
Pics later (if u need em)
Life consists not in holding good cards but in playing those you hold well. -Josh Billings \_(ツ)_/
Old 12-04-2012, 04:44 PM
Doc Sprocket's Avatar
Video might be better. What model clutch, how loose, what overall condition, etc?
Old 12-05-2012, 01:59 PM
cOw's Avatar
cOw cOw is offline
It is pretty loose. I have a video, but apparently it is invalid to upload...
Old 12-05-2012, 06:00 PM
mckutzy mckutzy is online now
You have to be a little more informative. We the outside world isnt psychic, so give all info available.
Old 12-05-2012, 09:15 PM
cOw's Avatar
cOw cOw is offline
I realize that, but I have no information really. I have a video, but the site wont let me upload it.
Basically, the outer housing on the clutch wobbles around alot, so it makes quite a bit of noise as I ride. I will try to upload pictures tomorrow, since the video dosent work
Old 12-05-2012, 09:26 PM
landuse's Avatar
landuse landuse is offline
Upload the the to YouTube, and then post the link here
Old 12-05-2012, 09:27 PM
OK...... Is a(TC) CVT or a centrifugal clutch... for starters. Thats what were getting at.
Old 12-05-2012, 10:00 PM
cOw's Avatar
cOw cOw is offline
It's centrifugal.
Old 12-06-2012, 01:07 AM
landuse's Avatar
I know this sounds dumb, but is the bolt holding the clutch onto the crank tightened properly
Old 12-06-2012, 04:14 AM
cOw's Avatar
cOw cOw is offline
As far as I can tell, yes.
  #11
Old 12-06-2012, 06:52 AM
fowler's Avatar
fowler fowler is offline
is the bolt too long and bottoming out on the hole
even if its just half a turn too long
does it make any funny grinding noieses when u spin it
when last did u oil it, the bushing aint shot
is the sirclip still on the front
or if its ssealed then is there any crackes in it
if u cant get a vid up then at least pics
how much movement
as in how far back and forth does it go
have u taken it off the crank to ensure the movement is between the ineer and outer parts and not the fit on the crank
That's not an oil leak
It's horsepower sweat
  #12
Old 12-06-2012, 09:42 AM
cOw's Avatar
cOw cOw is offline
Only the outer housing moves, the inner parts are secure. It is also very rusty, and I don't know how long ago it got oiled, I bought the whole cart used a few weeks ago
  #13
Old 12-06-2012, 01:56 PM
cOw's Avatar
cOw cOw is offline
Here you go, sorry for horrible filming.
  #14
Old 12-07-2012, 07:07 AM
anderkart's Avatar
anderkart anderkart is offline
The bronze bushing (thats pressed into the center of your clutch drum) is wore out.
If your clutch is a Maxtorqe brand, you could order a replacement bushing here: http://www.mfgsupply.com/gomini/gomi...chcentmax.html
The Following User Says Thank You to anderkart For This Useful Post:
cOw (12-07-2012)
  #15
Old 12-07-2012, 04:30 PM
cOw's Avatar
cOw cOw is offline
Is it possible to buy a bushing from a local hardware store, or do I have to order it special?
Thanks anderkart
  #16
Old 12-07-2012, 04:49 PM
cOw's Avatar
cOw cOw is offline
At the moment my clutch has a 12 tooth gear. The axle has 58 teeth. I have a second clutch with 21 teeth, would it be ok to switch them out? What would the impact be?
  #17
Old 12-07-2012, 05:06 PM
kendelrk's Avatar
kendelrk kendelrk is offline
redneck engineer
we need your tire size to tell, theres a speed calculator on the site homepage, im not the greatest with ratios but i beleive that thats a 5:2 ratio, so about a 1.75:1 ratio, im not sure but i think that would burn your clutch,
Great, now rebuild the engine.
Be a leader not a follower, but if your going to be a follower, follow the right leader
  #18
Old 12-07-2012, 05:51 PM
12T and 58T= 4.83:1
21T and 58T= 2.76:1
2.76:1 is waaaaaay too high, no matter what!
  #19
Old 12-07-2012, 06:44 PM
cOw's Avatar
cOw cOw is offline
Dang...well that's useless. The gear is welded to the clutch too...oh well T_T
  #20
Old 12-07-2012, 06:54 PM
cOw's Avatar
cOw cOw is offline
What is the optimum ratio to have?
If you wanna know i have 10" tires.
