Old 08-23-2019, 10:58 AM
batman3n1 batman3n1 is offline
Default Need Help
I need a solution that will keep the crankshaft from spinning when torquing the flywheel. I've heard where some have drilled holes in a TC keyed driver backplate, but can't find anywhere to buy just that part. I don't want to shove rope down the spark plug hole to keep the piston from turning either. I want something thats keyed that I can bolt to the block. Any suggestions? Anybody got a spare driver gear backplate they want to sell? Thanks
Old 08-23-2019, 03:09 PM
bob58o's Avatar
bob58o bob58o is offline
Assistant to the Manager
Ugga Dugga
There are two types of people. Those who can extrapolate from incomplete data
The Following User Says Thank You to bob58o For This Useful Post:
itsid (08-23-2019)
Old 08-23-2019, 04:47 PM
mckutzy mckutzy is online now
Heres an idea....
https://www.ezbore.net/Crank-Lock-p/ept99049.htm
But Ive seen a few others...
A Sprocket with a key that big enough to fit the PTO equipment mounting outer holes.
A hub or sprocket with a key thats welded to a long bar to hold onto... as to wrench with the other hand...
batman3n1 (08-26-2019)
Old 08-23-2019, 11:17 PM
itsid's Avatar
itsid itsid is offline
the fixed sheave of a TC driver can be bought seperately from mfgsupply.com
BUT only as an original Comet part for all I know..
and it's almost cheaper to buy a full TAvKit on ebay from china
But you can buy 3/4" keyed type B or C sprockets in nearly any kart shop.
A piece of chain bolted to some barstock can nicely wrap around such sprocket as a makeshift handle
(IDK what chain size those oil filter wrenches use but if it by chance is #35 or such... those might come in handy too)
The Following 2 Users Say Thank You to itsid For This Useful Post:
batman3n1 (08-26-2019), mckutzy (08-24-2019)
Old 08-24-2019, 08:20 AM
Oh ya forgot about the chain wrap type.. could do...
Old 08-26-2019, 10:17 AM
Originally Posted by mckutzy View Post
Heres an idea....
That’s the ticket!! Thanks!
Old 08-26-2019, 10:20 AM
If your handy.. could build one yourself..
batman3n1 (09-02-2019)
