Closed Thread
Old 08-17-2019, 05:25 PM
7sluck 7sluck is offline
Junior Member
Default Options for replacement drum/sprocket
I was wondering if there was a good alternate option that anybody else has had luck with on replacing the sprocket/drum on a Manco model 104D-29 GRASSHOPPER. I didn't want to go back to the two-in-one, sprocket/drum, but rather two separate parts to avoid the current situation of a broken drum. I was thinking about drilling and bolting the two together with some spacers even, but wanted to consult the more experienced crowd before I go and start modifying this, as this field is not my specialty.
Old 08-17-2019, 11:25 PM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
This is a one-wheel drive kart, yes?
The combination sprocket/drum is tried and true. One of my karts (live axle) has
that setup--they are bolted together.
Anything is possible, but more photos of the rear end would help tremendously.
I'm sure Dr. McKutzy would agree...
mckutzy (08-18-2019)
Old 08-18-2019, 08:02 AM
wenee9w wenee9w is offline
Hes right not much more solid set up than that for a yard kart. I have the manual disc on one of our karts the are worse. Bolting it with 4 , 5/16 bolts would be good.
Old 08-18-2019, 08:47 AM
itsid's Avatar
itsid itsid is online now
Quote:
No it's a tubed live axle in fact..
I wonder how you managed to brake the drum to be honest,
since it's the last thing I can see failing on a setup like that..
Nevermind
Now IIRC the drum is riveted to the sprocket not welded,
so you can drill out the rivets and rerivet a new drum if you want to.
(only a tad more difficult than un- and rebolting a drum)
And if I'm not mistaking that's been done since a bolt head doesn't clear the axle tube sufficiently but I might be misremembering... *shrugs*
The replacement has indeed a bolt on sprocket (and a keyed drum)
https://www.gokartsupply.com/sprocket.htm
scroll down to part 12087G
IDK if that fits (for reasons above) but usually gokartsupply is trustworthy enough to give it a try
PS do NOT use a spacer though.. the sprocket acts as a guide for the brake band.. and if that gets stuck between the drum and the sprocket or slipps off the drum you have either a non moving or a non braking kart (both is annoying )
Old 08-18-2019, 12:10 PM
mckutzy mckutzy is offline
I concure my good friend... more pics please...
Old 08-19-2019, 01:18 PM
Junior Member
Default Brake-no-brakey
I will do a little cleanup of the drive case tonight and take some more pictures.
As far as how it happened, I'm not for sure. I fired it up for the young'uns one day and I started to hear some metal-on-metal clanking and rubbing. Then I found the drum had come apart from the sprocket.
I was going to put spacers in-between them to properly align the brake pad with the drum portion. I didn't see any clearance issue right off the bat, but when I clean it up, I'll take a better look and post those pictures later.
  #7
Old 08-20-2019, 09:29 PM
Junior Member
Default A few more pics
So, I have not managed to get it torn apart yet. I've got too many irons in the fire right now, but it's next on the list. I'm assuming that I should probably get some new bearings for the kart since I'm going to be tearing it apart (I'm assuming there are bearings on the drive shaft)?
  #8
Old 08-21-2019, 01:28 AM
Hellion's Avatar
You can certainly get new bearings, or go hog wild and replace everything that's a 'wear item', and that's a good idea but you can also service the sealed bearings (if they just feel or sound rough but are still in spec). Pry open the bearing seal with a dental pick and repack it with a good grease.
Otherwise, buy new. 5/8" ID x 1-3/8" OD bearings are cheap.
Now the reason I thought your kart was 1-wheel-drive was the fact both rear wheels appear to have wheel bearings, but there is an axle too....Manco model 104: http://kartingdistributors.com/pdfs/...ed20020909.pdf
It certainly is an interesting failure--the sprocket and drum were sheared in twain (two).
Could be welded back together if you didn't want to fork over $42.95.
Closed Thread
