Closed Thread
Old 08-13-2019, 04:36 PM
Mcguyver Mcguyver is offline
Junior Member
Default Building an old race kart frame need some help
does anyone know the make of this kart frame? im building for my son and I remember years ago when i drove it that it always pulled hard to the left? i think. Id like to change the spindles angle.. right now they are at a pretty extreme angle (tops are inwards). I want the kart to drive straight. I have a feeling steering can be tricky some advice would be awesome!https://photos.google.com/photo/AF1Q...utp2q4b0LSKnhH
Old 08-13-2019, 05:57 PM
JTSpeedDemon's Avatar
2019 Build Off Winner!
Pics didn't work, here's how to successfully post pics:http://www.diygokarts.com/vb/showthread.php?t=737
If it pulled to the left, it may be an old speedway kart, which are designed to turn left better than right.
But without pics, it's a shot in the dark.
Currently Flathead-Crazed
The Following User Says Thank You to JTSpeedDemon For This Useful Post:
Mcguyver (08-13-2019)
Old 08-13-2019, 07:08 PM
Junior Member
Default pic
ok im trying to get a pic up
The Following User Says Thank You to Mcguyver For This Useful Post:
JTSpeedDemon (08-14-2019)
Old 08-13-2019, 07:14 PM
Junior Member
heres some more. any info would be cool . id like to have some history on it
Old 08-13-2019, 07:19 PM
Junior Member
Also another thing i was unsure of. the spindles had an upper and lower aluminum bushing. i used washers top and bottom to take out the slack ..it worked nice the wheels turn no problem and they are tight but not too tight . you can see them in the pic. just wondering if thats original way it was built thx!
Old 08-14-2019, 02:24 AM
landuse's Avatar
landuse landuse is offline
Interesting looking kart, but unfortunately I cant tell you what it is
  #7
Old 08-14-2019, 09:20 AM
Quote:
^^This.
I am clueless what it is, but I can tell you that it's not homemade, due to the precise bends and measurements.
Interesting kart for sure, chances are someone can help.
  #8
Old 08-15-2019, 09:55 AM
anderkart's Avatar
anderkart anderkart is offline
I don't know what brand your kart is, but Its very cool
Some of the older guys at this forum would probably know: https://www.vintagekartforum.com/index.php
Quote:
It's very common for (upper & lower) racekart spindle bushings to have an offset center hole, that way you can rotate the bushings to adjust caster/camber.
These offset-bushings are typically called Pills or Spindle Pills. Buying (or building your own) set of these Pills would probably correct your issue without having to replace the spindles...
You'd need to confirm if these Pills would fit your kart or not, but here's a link to some for sale: https://www.accelerationkarting.com/spindlepill.html
Here's a pic showing the top Pill on my old Invader racekart:
Closed Thread
