Closed Thread
Old 07-22-2019, 05:19 PM
YeaProbably YeaProbably is offline
i tinker...
Default idk how to setup a torque converter
I have the same engine as coleman ct200u in a gokart its a honda clone/ off brand predator 79cc but it has 98cc.https://www.walmart.com/ip/Coleman-Powersports-100cc-Gas-Powered-Go-kart-Black-and-Red/480257966?wmlspartner=wlpa&selectedSellerId=0&adid =22222222227102818906&wl0=&wl1=g&wl2=c&wl3=2176680 19152&wl4=aud-566049426705:pla-353066965138&wl5=9010842&wl6=&wl7=&wl8=&wl9=pla&wl 10=8175035&wl11=online&wl12=480257966&veh=sem&gcli d=Cj0KCQjwvdXpBRCoARIsAMJSKqKt8vaiwqyJ7ZHcBesjkSUJ R-snm2O7V3PQHI-8x7QSVdwmFysoVd0aAhQxEALw_wcBi was planning on putting this torque converter on it https://www.amazon.com/Torque-Conver...05416315&psc=1 but i have no idea how i would do it. there a picture of the clutch and the current gear setup VVVVV(dont message about how bad the clutch is ik)
a few questions:
1.where do i put the clutch with the torque converter?
2.what do i do with my other gears?
3.how do i attach the torque converter to my other gears?(i can move my engine if needed)
4.does the torque converter replace the clutch?
Old 07-23-2019, 10:19 PM
Zombient68 Zombient68 is offline
Junior Member
That's not a torque converter, fam. That looks like a setup that's trying to gear it down.
Old 07-23-2019, 11:10 PM
mckutzy mckutzy is online now
Your kart doesn't need a TC, could use a new 212...
The Following User Says Thank You to mckutzy For This Useful Post:
YeaProbably (07-31-2019)
Old 07-24-2019, 12:47 AM
landuse's Avatar
landuse landuse is offline
Quote:
I would probably agree with Mkutzy here. Once you have a larger engine, you will probably not need a TC and you could just use the gearing that you have.
If you do want a TC, there are many examples of them on the website. I would snoop around a few threads and check them out.
Comet identification, installation and belts. Sprocket and spring changes. Have a look at these links to see what you are getting
http://www.gokartsupply.com/identify.htm
http://www.gokartsupply.com/tcbelts.htm
http://www.bmikarts.com/PDF/Comet_40series.pdf
We can always help you get going if you want one. You will not need the centrifugal clutch that you have on your kart now if you get a TC.
The Following User Says Thank You to landuse For This Useful Post:
Old 07-31-2019, 06:13 PM
i tinker...
ok i was thinking about getting a 212
---------- Post added at 07:13 PM ---------- Previous post was at 06:55 PM ----------
Quote:
i know its not a torque converter i was talking about getting one lol
Old 07-31-2019, 08:24 PM
mrdeadman1 mrdeadman1 is offline
ok well if you get a 30 series tav it just bolts on, no guess work it's pretty straight forward.
---------- Post added at 08:24 PM ---------- Previous post was at 08:22 PM ----------
also that 3 hp engine isnt going to do it. it would be the same as the ct100 not the 200 it uses a 196 cc engine
  #7
Old 08-05-2019, 04:35 PM
i tinker...
my dad says the go kart is too small for that engine D=
  #8
Old 08-05-2019, 06:59 PM
it'll bolt in I put a predator in my coleman ct100u mini bike
Closed Thread
