Closed Thread
Old 05-19-2019, 05:55 AM
PLance1 PLance1 is offline
Junior Member
Default Baja Magnum?
I'm new here. When I was a kid I kept getting catalogs from some company that sold the "Baja" which was 5 hp and the "Baja Magnum" which was 8 hp. I saved up my paper route money to buy one but when I finally had enough money my mom confiscated all my funds. I am curious about this brand of go cart, when I do a google search I don't come up with anything but maybe I'm not searching hard enough. Does anyone have one of these? Thank you.
Old 05-19-2019, 07:56 AM
itsid's Avatar
itsid itsid is online now
the Baja 5HP is a Model name for a
Manco 285-16
the more common name would be DINGO (since the 285 is one of the Dingo frames..)
then there was a Phoenix Baja 200 (also Manco, a 285-36 or various flavours of the 286 [6hp] and so on)
IIRC there was no 288 (same frame but 8hp)
but there was the 388 (similar frame 8hp)
285-16:
https://americanlandmaster.com/pdfs/...5162285182.pdf
388-15:
https://americanlandmaster.com/pdfs/...nual_38815.pdf
if it was ever sold under the name of Magnum escapes me;
there's a Manco Magnum express however that's a two seater kart nothing like the Dingos above.
Anyways chances are some magnum decals have been used by Manco
Old 08-16-2019, 02:24 AM
Greg R. Greg R. is offline
Junior Member
Default Baja Magnum
The Baja Magnum was similar to the Dingo....but not the same machine. It had turf style tires, a differential rear axle, dual independent rear brakes, and handlebars instead of a steering wheel. I had one as a kid and it was a beast! Over powered for a 11-12 year old....that is for sure. With that torque converter (and the way it was geared) it had so much low end torque that on a good surface, it would pull the front wheels 2 FEET off the ground. The top end was about 45mph. No gas pedal but a twist grip throttle instead. You could whip that thing through the turns by hitting either of the dual brake levers......just lock up the inside wheel during a turn and twist the throttle a quick snap and hold on because it felt like you were riding the Tilt-a-whirl at the county fair. As much as I pounded it for a few years, the differential was really durable.
The Following 3 Users Say Thank You to Greg R. For This Useful Post:
Hellion (08-16-2019), itsid (08-16-2019), Mrmonk7663 (08-16-2019)
Old 08-16-2019, 02:49 AM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
That's a nice ad ^^
Thanks for sharing it, new guy.
Also shows JTSpunkwagon's ride du jour--the Starbird.
Old 08-16-2019, 04:02 AM
Looks like a Bird Engineering Kart.
Old 08-16-2019, 06:26 AM
itsid's Avatar
Quote:
HA... because it IS!
That's the successor to the Bird Baja I was talking about earlier this week..
didn't know it's called "Baja Magnum"
Dang it.. should've rang a bell when I saw that floor decal
Here it is
in 'survivor' state
Closed Thread
