Go Back   DIY Go Kart Forum > Other Stuff > More Builds
Closed Thread
Old 11-01-2017, 07:34 PM
karl's Avatar
karl karl is offline
Default Turbo Ranger
I bought a 94 ranger for $400. The transmission leaked when hot, I fixed it , drove it for 5,000 miles, then the trans puked all its atf. I got tired of dealing with the POS A4LD. And the 4.0l was not very impressive.
I came across a 79 mustang cobra 2.3l turbo and t4 Manuel for free.
It has a factory carbed draw through turbo setup.
You can see where this is going. I need to convert the truck to 2wd and lower it with street tires.
I will use the factory turbo setup so I can drive the thing then upgrade the system later on.
Should be unique.
The Following 2 Users Say Thank You to karl For This Useful Post:
ezcome-ezgo (11-02-2017), RangerRob007 (05-30-2018)
Old 11-01-2017, 07:36 PM
karl's Avatar
The motor and turbo looks low miles, not much wear at all
The Following User Says Thank You to karl For This Useful Post:
Old 11-01-2017, 07:37 PM
anickode's Avatar
anickode anickode is offline
Should be unique.
Shoot, I'd keep it 4wd, throw some blocks under it, drop some monster gears in the diffs, and put it on some 35s!
The Following User Says Thank You to anickode For This Useful Post:
KingCobra (11-25-2017)
Old 11-02-2017, 09:31 AM
karl's Avatar
Quote:
I would like too but I need to keep in budget. The transmission is for 2wd
And I would like to drive it daily.
Old 11-03-2017, 01:21 AM
OzFab's Avatar
OzFab OzFab is offline
Well, at least now you know why it was $400
Correct me if I'm wrong but, isn't a 4.0 an I6?
Old 11-03-2017, 07:09 AM
ezcome-ezgo's Avatar
US Spec Ford Rangers came with either an I4 (2.3L) or V6 (2.9L, 3.0L or 4.0L). I have a '92 with the 3.0L and 5sp manual. Parts are becoming unicorns.
The Following User Says Thank You to ezcome-ezgo For This Useful Post:
OzFab (11-03-2017)
  #7
Old 11-03-2017, 08:54 PM
karl's Avatar
I know I am replacing the 4.0l v6 with a 4 banger, but it will be worth it.
The 2.3 is able to handle more power and it is cheaper to build.
It's looking very blue!
ezcome-ezgo (11-06-2017)
  #8
Old 11-06-2017, 09:05 PM
karl's Avatar
The clearances check out good enough so I ordered standard rod and main bearings. I am lightly honing it and using new standard rings. Then I can reassemble with all new hardware and gaskets.
ezcome-ezgo (11-07-2017)
  #9
Old 11-07-2017, 04:55 PM
Kartorbust's Avatar
Kartorbust Kartorbust is offline
33s are about the largest you can put on these Rangers with twin traction beam. They are not strong enough really for that large of tire. Could drop a Dana 44 axle on the front, but that's a ton of money and work and not worth it.
You going to use the T4 manual with the new engine or you going to locate an automatic instead? I can see why you'll want to do 2wd because that manual was never setup for 4wd let alone I doubt anyone makes an adapter for it. However if you are fully converting to 2wd, I'd keep it at stock height or raise it 2" and put a locker in the rear end. They call it Pre-Runner. Do you know if it's a 7.75" or 8.8" rear end on the truck? 8.8 is easy to find lockers for, the smaller ones not so much.
  #10
Old 11-07-2017, 06:54 PM
karl's Avatar
Quote:
Yes I plan on using the t4 Manuel, as I prefer stick and it is robust enough to hold whatever my little 2.3 can do.
My truck has a factory 8.8 rear end with a limited slip diff and steep gears. No reason to mess with that.
I original plan was to make it pre-runner style, but with limited power output the truck would be funner with smaller street tires. Less rolling resistance, and better gear ratio for acceleration.
I am looking for this truck to be sporty, handle and stop well, sound cool, and get decent gas mileage .
A ford motorsport cam so it lopes at idle and a 2.5in exhaust should make it sound good.
  #11
Old 11-07-2017, 08:23 PM
Ebrownie's Avatar
Ebrownie Ebrownie is offline
That looks like it will be fun! Yeah that engine with 33s or 35s would be a little sluggish. I noticed that my ram got a decent amount slower when I put 34" tires on it, from the stock 31.5". And that has a hemi! (So it also gets 11 mpg now ) Smaller tires will make it more fun, since it already won't have much off road potential being 2wd.
Put a flowmaster 40 series on it, it will sound about as mean as a four cylinder can sound.
  #12
Old 11-08-2017, 01:07 AM
Bwdeaton Bwdeaton is offline
My 05 ram was on 305s (about 34") for a while before going to stock height tires (265). I got the same mileage pretty much (18-20 depending how I drive). It chirps the 265's pretty easily.
  #13
Old 11-08-2017, 07:20 AM
The I-Beam front ends were gone in 93.
  #14
Old 11-08-2017, 07:27 AM
Ebrownie's Avatar
Quote:
You must have had mds then or something, because there's no way I could get 18-20, maybe 14 if I drove it really nice(mine is an 04). The main problem is most of my daily drive has a 45 mph speed limit so the tranny never shifts up and just runs at 1700 rpms. Yeah i shredded the 265s over the last couple weeks before I got the new ones
  #15
Old 11-08-2017, 09:19 AM
Mine has the Cummins. They were taller tires but not really aggressive. I get about 20-21 keeping it at 65 on the highway, and about 18-19 on my daily commute with some country roads mostly 55mph with stops.
Sent from my Nexus 6P using Tapatalk
  #16
Old 11-08-2017, 08:11 PM
karl's Avatar
Parts are arriving! Should take about $300 to make the motor and trans complete and roadworthy.
  #17
Old 11-12-2017, 06:55 PM
karl's Avatar
I honed the block , set all the ring gaps, and put the bottom end together with new bearings and seals.
ezcome-ezgo (11-13-2017)
  #18
Old 11-12-2017, 07:03 PM
MTNSleder MTNSleder is offline
Banned
That's a cool engine. Looks like Bob's mini bike...
  #19
Old 11-12-2017, 07:14 PM
Kartorbust's Avatar
You going to use the same turbo or different one? I never looked at the old Fox body Mustangs much, they are like the red head step child of the family, but did this have a turbo intercooler? If not you going to add one for an extra boost in power?
  #20
Old 11-13-2017, 07:28 AM
karl's Avatar
draw through = no intercooler
most weak
water /meth injection maybe
Closed Thread
