Go Back   DIY Go Kart Forum > Other Stuff > Off Topic Forum
Old 07-18-2008, 11:37 AM
oscaryu1 oscaryu1 is offline
Default Clone finally runs...
... and sounds like stock. Used the stock muffler for the neighboors. It was still in the morning
Mods:
GX160 14cc Head
SS Valves + Retainers + Keepers + Lash Caps
Flat Top Piston
1.2:1 Ratio Rocker Arms
Chromoly Push Rods
Super Dyno X .275" Lift Cam
ARC Billet Rod (Stock Length)
ARC Billet Flywheel (Non-adjustable Hub)
8 Degrees Advanced Timing
K&N-Clone Air Filter
Billet Air Filter Adapter
26lbs Valve Springs
Stock Muffler (For the neighbor's sake)
Doesn't sound like much:
Old 07-18-2008, 11:38 AM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
Wet or dry nitrous? Thats a pretty high compression setup, does it run pump gas?
Old 07-18-2008, 11:39 AM
ed1380's Avatar
ed1380 ed1380 is offline
Banned
how much hp stock vs now?
Old 07-18-2008, 12:27 PM
crazycart's Avatar
crazycart crazycart is offline
RedNek Engineering
Dude i would stop screwing around with those stock honda carbs, get a mikuni it will really wake that thing up.
For some there is therapy...For me there is motorcycles...
Old 07-18-2008, 01:37 PM
Yes, right now it's running a mixture of 89/93. Getting pure 93 today.
You tell me. There aren't any guys with Dynos I know of here. I could send it do NR and get it Dynoed for like $75, but who knows that UPS will do to it. People with similar setups are around 20-25HP.
First things first. Put that GX390 carburetor n' stuff on. It runs lean now, need to straighten that out. When I really "get to it", I'll be switching to a 22mm Mikuni (Hopefully genuine one), and alky (I have some professional help )
The carburetor adapter adapts GX390 carbs and Mikuni 22's. Another goody. I might take a video of it with a pipe today. Today or tomorrow. Right now my top priority is to get it to run on that kart.
EDIT - At time of filming, it was still being broken in. Was running dino oil WalMart brand 10W-30 Motor oil. Synthetic doesn't seat the valves correctly.
Stock head is around 22cc. The dished piston also took away around 8cc. So I've earned around 16cc's back.
Old 07-18-2008, 02:18 PM
jr dragster T's Avatar
jr dragster T jr dragster T is offline
Whos your profesional alky help huh?
Old 07-18-2008, 10:22 PM
The guy across the street :rolleyes3:
Nah, it's (Pointing up)
:p
Old 07-18-2008, 11:11 PM
NITROUS!! Yay! As soon as you get your mikuni 22 i can start helping you for a alky setup. I would say a #20 main jet would be PERFECT. JK
Old 07-19-2008, 08:52 AM
Keyword "when"
Muhahahahaha
Old 07-19-2008, 10:25 AM
Guess what Oscar? This winter I am going to do some mod's to my clone. This is what I plan. Remove goverener, Billet intake 22 mm mikuni carb and the UNI air filter. Also Billet rod and Billet ARC flywheel. Sound good?
  #11
Old 07-19-2008, 10:31 AM
Yup! But it depends on your budget. If you wanna save $25, you could get the aluminum flywheel, ect...
This is where I can help
  #12
Old 07-19-2008, 10:53 AM
How come it says on AGK to set the valve lash after removing the governer? I dont need too? and NO I am going the safe way and buying a ARC billet flywheel. But realy I dont wind out my kart alot so who says I even need a billet rod and flywheel? I RARELY even have it doing 3600 RPM stock!
  #13
Old 07-19-2008, 10:58 AM
Kartless....
Im pretty sure the PILOT on my kehin thats on my honda spree is bigger than that!
  #14
Old 07-19-2008, 11:40 AM
I was joking around with him. Because he was saying he has profesionaly Alcohol carb help (meaning me) and I was joking my saying # 20.
  #15
Old 07-19-2008, 12:02 PM
Kartless....
Yes I know.
  #16
Old 07-19-2008, 05:49 PM
Awww... I bought a #20...
Jk jk :p
GX390 setup didn't work. It was 1) Don't run or 2) Run only when gas down plug hole and runs very fast idle...
Oh well
  #17
Old 07-19-2008, 05:52 PM
Took the kart out for a spin today. Sounds really low with the stock muffler!
  #18
Old 07-19-2008, 07:50 PM
Jk jk :p
Oh well
Mikuni time!!
  #19
Old 07-19-2008, 09:36 PM
gocartkid's Avatar
gocartkid gocartkid is offline
Bad Attitude
That means it's a sleeper! Now go sneak up and someone in your neighborhood who also has a kart and BLOW THEM AWAY!!!!!
Nice job on the engine, btw.
Build it... drive it... break it.... fix it... repeat....
  #20
Old 07-19-2008, 10:18 PM
Thanks haha!
Well, I'm uploading a video of a low speed spin around the neighborhood (Who would want to drop a $300 digital camera?!)
It works great! It really is a sleeper, even with the candy cane header.
Now to finish up my Briggs 5HP...
