Old 02-16-2020, 07:24 AM
DFWRealist DFWRealist is offline
Default Engine Stalls Turning Right.... Even Curving to Right
I have a Carter Bros 2 seater I am rebuilding.
I replaced the engine with a new 212 Predator and also replaced the beat up 20 Series torque converter with a new 30 series.
The rear axel is a limited differential drive unit. So, both wheels are not on a solid, 1 piece axle. The gear box is fine and it has plenty of gear grease. Both wheels spin as they should with that type of axle.
I got all the parts installed and it should be good to go BUT.....
EVERY time I apply any turn to the right, the engine stalls out very quickly, regardless of how fast or slow I am driving.
The kart has a 3/4" jackshaft with a 10-tooth jackshaft sprocket.
I have a #40 chain on it.
The big drive sprocket has 54 teeth on it.
What do I need to do in order to turn right without it stalling??
Thanks
If "Stupid" had a city limits...It would be around ME!
Old 02-16-2020, 07:37 AM
Karttekk Karttekk is offline
Bypass the low oil sensor on the lower rear section of the engine. Use the wiring for a kill switch.
The Following User Says Thank You to Karttekk For This Useful Post:
DFWRealist (02-16-2020)
Old 02-16-2020, 07:59 AM
Default I just found a video on youtube...
I just watched a video that said exactly what you just suggested.
Its a relief that it is that simple to fix vs changing out sprockets, etc.
Thank you!
