Closed Thread
  #21
Old 11-10-2019, 07:34 AM
JTSpeedDemon's Avatar
2019 Build Off Winner!
So, BirdFanatic, are there any pics of what this bonkers engine will go on?
Currently Flathead-Crazed
  #22
Old 11-10-2019, 12:02 PM
Randy H Randy H is offline
Some inexpensive parts here to keep a Vanguard V-Twin alive.
http://www.cartpartsplus.com/index.p...guard%20#intro
These sites have high performance goodies.
https://www.arcracing.com/,
https://www.eccarburetors.com/
https://www.carrierperformance.net/
https://performancevtwins.com/
A stock cam can be advanced a tooth instead of a 23 hp cam or racing cam. Some heads have desirable aluminum rockes for mild performance, on Ebay frequently.
A few weak points are connecting rod bolts that loosen up, and a spring pin on the cam that works it's way out. Blue and green loctite respectively can be used to remedy those issues.
Weak pushrods and retainers are potential problem areas.
Lots of info, but you have to register at BigBlockCarts.com, very little activity anymore.
http://www.heymow.com/index.php?PHPS...g4n6t241e2&and
http://bigblockcarts.com/
Closed Thread
