Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Closed Thread
Old 04-10-2017, 04:48 AM
Bubba_Z Bubba_Z is offline
Bubba_Z
Default Yerf Dog
Okay, so I know what is store for this kart I am officially renaming it...
God-Frey.
Simply because Yerf Dog got it backwards.
Moving forward any reasonableness between this and a original YefDog is completely coincidental.
B
Old 04-12-2017, 09:10 PM
Bubba_Z
I see a "engine upgrade" in the God-Frey future.
First we need to beef up the chassis.
Old 04-13-2017, 08:03 PM
Bubba_Z
Default Rear Pivot pt2
The Original Yerf Dog pivot is 2 C brackets and a bolt. Even at best
very sloppy.
My first idea was to use short pins on ether side, but then
I realized with self aligning barrings the kart would "droop" to
the end of the outer race. This would no doubt snap the casting.
So, Solid bar is the only choice unless I weld the pins directly to
the rear end. I may go that way when I install the big block because
I will need that middle area for the jack-shaft.
Old 04-18-2017, 09:09 PM
Bubba_Z
Default Rear Pivot Done...Well, done enough to ride
Before and after videos....
Waiting for my 24" shaft....A old axle will do for now
Next, Move the shock mounts for more "Load"
TY, Whitetrashrocker
then add a rack to the steering, My design works, but it still turns
like a $30 gokart.
Old 04-19-2017, 05:48 PM
qtband's Avatar
qtband qtband is offline
What about cutting the shaft down to 2 - 6" pieces. Cut a groove on each side and use a c-clip. It would be less weight. Anyway, it looks like a HUGE improvement.
I asked God for a go-kart, but God doesn't work that way. So I stole one and asked for forgiveness.
Old 04-19-2017, 07:49 PM
Bubba_Z
That was my original thought. look at Pic #2 in my Rear Pivot pt2 Post
But being self aligning barrings it would "Droop" for lack of a better term. Picture the rear end dropping and the kart raising. The self alignment would angle the pins " \ / " and break the casting.
I know 1" is overkill, but I am glad i did due to the 24" span.
"0" flex.
  #7
Old 04-19-2017, 08:03 PM
Bubba_Z
Default Question about the 40 Series Comet Driven
Clearly the installation shows the Driven running inboard.
Can it be ran outboard?
I need the clearance for the chain.
Also, started my jig to set the CD on my home made Jack Shaft.
  #8
Old 04-25-2017, 08:25 PM
Bubba_Z
Default Progress is slow
I only have a few hours each night to work on this, I have decided to
make the motor plate for the 460cc removable. It just bolts into the mount for the 6hp. And allows the original adjustment for the chain.
  #9
Old 04-26-2017, 03:10 AM
Sgona101 Sgona101 is offline
Junior Member
I've seen some yerf dog karts that where the brake is at (on the left side) the tube usually starts to bend what do you suggest is best. To build a new heavy dutty frame or to somehow reinforce it?
  #10
Old 04-28-2017, 08:51 PM
Bubba_Z
There are a few different designs of Yerf rear ends, I would need to see a picture to help. If you look in my Introduce Yourself post. You will get a idea of what I did. (Abandon it all together)
http://www.diygokarts.com/vb/showthread.php?t=36084
  #11
Old 04-30-2017, 04:23 PM
Bubba_Z
Added a mid axle hanger.
  #12
Old 04-30-2017, 08:10 PM
Bubba_Z
Engine mount is done. Also added a video to my YT.
Monday night I mount the 460cc (film at eleven)
The Following User Says Thank You to Bubba_Z For This Useful Post:
Flyinhillbilly (04-30-2017)
  #13
Old 05-01-2017, 11:48 PM
Bubba_Z
okay , so not 11....more like 1 am. I have decided to run a third bearing on the jackshaft. Just to much power to trust a 5/8 shaft and no support on the outside. Parts ordered from gopowersports.com Guess I will tie down the seat while waiting.
  #14
Old 05-08-2017, 10:21 PM
Bubba_Z
Default Update
Moving forward. Got the jack shaft support finished. Test fired the motor. See my YT channel for all the videos. YouTube = HTHCLLC
Motor runs great but having carb overflow issue. I would love some
Comments, Advice/Help with this to see if I am thinking clearly.
  #15
Old 05-09-2017, 05:16 AM
gman3850 gman3850 is offline
On my built gx390 the cheap filters cause my carb to overflow. I switched out to a real k&n filter and it resolved most of the issues. Still overflows when it gets dirty.
The Following User Says Thank You to gman3850 For This Useful Post:
Bubba_Z (05-09-2017)
  #16
Old 05-09-2017, 07:13 AM
Bubba_Z
I never would have thought of that. I will try that also. Thanks
Question, Anyone else vent there tank like a atv does?
  #17
Old 05-09-2017, 01:17 PM
yes all the stock engines have a small vent, well at least mine have.
Bubba_Z (05-11-2017)
  #18
Old 05-11-2017, 10:00 PM
Bubba_Z
It helped, the cap on the tank I savaged from a ATV, the cap was from a gas can...Not oem for the tank and was causing vapor lock. The return didn't work (closed system) and I am sure, run long enough it would have starved the carb. Talked to a Tech at Vegas carts about rope starting this motor and what a pain in the @$^ it was (Great customer service BTW) and he reminded me that all tanks must be vented. ALL TANKS. Got a Coleman starter and starter nut from ARC Racing. I will never pull start a Big Block again, Just say "NO" to rope. My hand still hurts from the kickback pulling the rope out of my hand......
---------- Post added 05-12-2017 at 12:00 AM ---------- Previous post was 05-11-2017 at 11:53 PM ----------
Walk around. Got to test drive tonight.....just to see how much power I have to work with.
(OMG) I said in my introduce yourself video 3x would be "Sick".....this is 4x "Insane Power"
One step above sick....
I have a few items on my punch list before I make a "Drive video" But I will give a spoiler, I might need wheelie bars
  #19
Old 05-12-2017, 01:57 AM
nice setup but i think you are going to be disappointed on how the comet 40 works for you. With the comet 40 i can feel the belt slip every time i floor it. Running it on the drag strip when i have it setup to a 3k stall i burn threw a belt every 5 runs down the track.
Bubba_Z (05-12-2017)
  #20
Old 05-12-2017, 05:11 PM
Bubba_Z
Do you run your Driven inboard or out?
I may have to go bigger if I do...so be it.
I made the upgrade so I can go back to the 212 if I wish. (All bolt on) And I can always use a 40 on something. This motor is not staying on this kart forever, I was just dying to feel the pull of 27hp. Most all my runs will be dirt so its hard to tell wheel/belt slip. I will keep a eye on wear, that would be the tattle tell.
Closed Thread
