Old 10-06-2016, 12:57 PM
Scotfree1993 Scotfree1993 is offline
Default B&S Carb Question
Picked up an old B&S 5 HP motor. (FREE) Carb is missing.
Model # 130232 Tyoe: 3029-01
Found a replacement online for $90. That's crazy. I would like to rebuild the motor for a go kart. Could I put another carburetor on it?
Old 10-06-2016, 01:18 PM
Whitetrashrocker's Avatar
Whitetrashrocker Whitetrashrocker is offline
As long as it's a comprible size to the original. You might have to get creative for the mounting and air filter.
New engines are going for just a few more dollars than that carb.
Old 10-06-2016, 05:34 PM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
You can find old B&S carburetor "hulks" on fleabay all day long for cheap. You could get creative and look for a few in your local lawnmower repair shop as well. Then rebuild them for a few bucks.
Otherwise, there are aftermarket or other alternatives: Tillotson, Mikuni..basically any carb would work as long as you have the proper interface to attach it to the engine.
Check out Kentucky Boy's threads--he's done a few on the subject:
http://www.diygokarts.com/vb/showthread.php?t=33377
But it's actually pretty hard to beat a factory Briggs Flo-Jet or Pulsa-Jet carburetor.
Old 10-06-2016, 07:31 PM
Joe-405's Avatar
Joe-405 Joe-405 is online now
Enjoying New Projects
Those carbs are junk. When they work they're awesome but if they fail your screwed !
I work in a small engine repair shop and those are the worst to fix.
I would find a different alternative to anything without a gas tank attached to it !
Old 10-06-2016, 09:12 PM
OzFab's Avatar
OzFab OzFab is offline
How's your fab skills?
Old 10-06-2016, 10:09 PM
chancer's Avatar
chancer chancer is offline
ɔ ɥ ɐ u ɔ ǝ ɹ
Originally Posted by OzFab View Post
Thats one way. The cheapest with a 10 dollar Clone carb.
But For way less than 90 the Mikuni suggested by hellions link to
Kentucky boy is a better carb for 25 bucks.
Why don't you, go back to your double wide and fry something!
