Old 12-19-2017, 08:59 PM
Duryl Duryl is offline
Default Supermarket Sweep showdown
Grab a pair of matching pastel sweatshirts and get ready for Supermarket Sweep Octane Edition.
We have been working on this project off and on for awhile. We wanted to build something fun and unique. Everything that is on the kart has been bought off Craigslist, OfferUp, etc or local kart shop, Precision Karting of Dallas, that helped out with used parts. **** we even scored 60 Mojo tires for almost nothing, thanks to a nice couple.
This is what we have done so far-
-1” rear axle with disk brake
-11” wide tires on the rear and 4.5” for the fronts
-Chopped up a donor kart for the entire front end(steering shaft, linkage, knuckles) Welded the donor kart front end to the rails of the shopping kart and reinforced with flat plate.
-Made motor mount plate with gussets. Using a hopped up Predator 212
-Flipped the “bread” basket to the outside of the kart. This will hold the gas tank
-Cut a hole in the bottom of the basket for your legs to go through and your back will rest up against the back of the basket. The kart sets very low and you can swing your leg over and in without climbing on anything.
Also the kart measures 4 feet wide from outside edge to outside edge of the tires!
Like two little kids we rolled it outside once we finished the final welds and mounted the tires. Did a couple of push test and rolled great, no hop from the axle and rolled straight. Also the front end has a little camber, so the kart turned great.
Still need to finish the brake caliper mount. Gas tank. Right now we are throwing an idea around to use road bike “ram horn” handlebars for the brake and throttle pedals. Sounds strange but it works in the mock up stage and looks good too. Can’t wait to get this girl to the supermarket for a couple of hot laps
C37352D6-C7D3-4429-AA98-886B2937FEF6.jpg   84752D71-D06D-498A-B165-978AFA3BEAD0.jpg
E55FF0B6-7A2B-4A52-94A1-494CEE263646.jpg   5CBD140C-A5D4-4484-AB59-2C32270C7BBF.jpg
AF3A2D9C-3617-4352-80B1-63A5A51853A4.jpg   CD4F622B-E9B5-414E-9BC2-8FAF0D7F1238.jpg
The Following 4 Users Say Thank You to Duryl For This Useful Post:
bob58o (12-19-2017), ezcome-ezgo (12-20-2017), KingCobra (12-28-2017), tgus3 (12-20-2017)
Old 12-19-2017, 11:05 PM
landuse's Avatar
landuse landuse is offline
That is a neat build!! The only thing I might worry about is the high center of gravity. You are sitting quite high up and in fast turns you might tip over.
Old 12-23-2017, 07:05 PM
Thanks. Yes it sits a little high. But it won't be hucking around corners. Mainly ripping down the streets
Old 12-24-2017, 08:54 AM
Nosandwich's Avatar
Nosandwich Nosandwich is offline
The REAL Poboy
Call me from jail.
I do not recall Congressman.
Old 12-28-2017, 11:19 AM
Kelly Wood's Avatar
Kelly Wood Kelly Wood is offline
The Mad Kartist
And the store that's missing their shopping cart? What about them huh?
Get some wheelie bars.
Kelly "Mad Kartist" Wood - http://www.diygokarts.com/vb/album.php?u=9686
The Following User Says Thank You to Kelly Wood For This Useful Post:
Old 12-28-2017, 02:13 PM
Kartorbust's Avatar
Hope you'll have plenty of visibility.
Sent from my SAMSUNG-SM-G935A using Tapatalk
KingCobra (12-29-2017)
Old 12-28-2017, 02:52 PM
KingCobra's Avatar
KingCobra KingCobra is offline
TROLL CRUSHER INC.
Target just called asking where their shopping cart was..... Oh wait, never mind, they said they retired the old 'wire' ones centuries ago.....
Even though I walk through the darkest valley, I will fear no TROLL...
Old 12-28-2017, 03:40 PM
Nosandwich's Avatar
The REAL Poboy
Coming soon: the Kelly Wood "blue light special!"
Old 12-29-2017, 10:40 AM
Functional Artist's Avatar
Looks, Kool but, Dangerous @ the same time
...dual purpose
Do you "pad" anything?
...butt protection
...back protection
...knee protection
Old 12-29-2017, 01:32 PM
Kartorbust's Avatar
Might be Super Saver? I'd rip one off from Costco, they are extra wide and might be a bit longer.
  #11
Old 12-29-2017, 04:26 PM
KingCobra's Avatar
TROLL CRUSHER INC.
I think it would just be cool enough to put cool wide slicks on a cart and enter the store with it. Might get a lot of attention but they can't stop ya...... Get some sound effects speaker mounted under it concealed with engine sounds, horn, etc....... Walk into an empty isle tap a siren sound and walk out the other end........
  #12
Old 12-29-2017, 05:18 PM
Nosandwich's Avatar
The REAL Poboy
Meh...."bag lady" handle bar "drag queen "....
How is it I'm not in a straight jacket?....(Oh...I forgot, I got out!)
  #13
Old 12-30-2017, 10:05 PM
Ha! We “built” the shopping cart to grocery store specs. Any likeness to another grocery store cart is merely a coincidence. Yes there will be padding for a seat, back support,and around the floor of the basket where your knees are. We have laughed about running it in a grocery store just to get a quick photo.Will update with more photos as we get closer to finishing
  #14
Old 01-31-2018, 09:01 AM
Update-
We hit the project hard. We buttoned some more final welds, solved and installed the pedal placement, installed heel support, acquired cables and hardware, replaced bad head and pull start on motor. Sorry no pictures yet, we didn’t finish till midnight. Trying to finish up for the meet up at Go Powersports on Saturday
  #15
Old 01-31-2018, 09:10 AM
bob58o's Avatar
bob58o bob58o is offline
Assistant to the Manager
Walking by Jewel yesterday, I actually thought of this build. I asked myself, "What happened to that shopping cart build? Did he turn too fast and perish like the expired milk in the dumpster?"
Guess not. Thanks for the update.
There are two types of people. Those who can extrapolate from incomplete data
The Following User Says Thank You to bob58o For This Useful Post:
Duryl (01-31-2018)
  #16
Old 01-31-2018, 11:21 PM
landuse's Avatar
Nice!! Post some pics when you can
  #17
Old 04-27-2018, 09:48 PM
Default Don’t call it a come back.
Sorry for the long over due updates. But pull this one out of the “Projects started and never finished file.” But the Chopping Kart is running around in the streets now. It runs and drives great. We are super stoked on this project becoming a reality. We learned a lot, expanded our creativity, and most of all had a great time doing it. The main goal was to push ourselves and build it just to see if we could. And I feel that we have accomplished that goal. We do have some little details to address, better gas tank, kill switch, seat, carb and engine upgrades to really wake it up.
5F89A1C5-963A-4D9D-ADCA-5AB4F13339A1.jpg   893977A7-630D-43AD-A500-406DDFF0E5EA.jpg
EAF6BE22-9A3D-4F1F-81F3-DD040AA728D0.jpg   E25944C5-A35B-4E68-82D6-4A7785B953F9.jpg
The Following User Says Thank You to Duryl For This Useful Post:
bob58o (04-28-2018)
  #18
Old 04-28-2018, 07:11 AM
TT540 TT540 is offline
Newb
Dope.
