  #21
Old 10-01-2017, 12:54 AM
pRoFiT's Avatar
pRoFiT pRoFiT is offline
Can't buy it?, build it!
Originally Posted by KingCobra View Post
OK, that does it, I quit...............snapping tires? Gadzooks!!!
Yah the center hub that holds the bearings is pressed in place not welded. So any real amount of side force like turning, could snap it off.
I welded mine together, purchased good bearings...and after 15minutes of fun I replaced the tires with Walmart tractor tires. $15 each. No problems with them so far. But Iíve only put a couple good hours on them. Need to find a good place to ride.
Stupid kalifornia gokart laws...
Anyways, be safe out there.
2016 diygokart Contestant http://www.diygokarts.com/vb/showthread.php?t=33422.
The Following User Says Thank You to pRoFiT For This Useful Post:
KingCobra (10-01-2017)
  #22
Old 10-01-2017, 05:25 AM
KingCobra's Avatar
KingCobra KingCobra is offline
TROLL CRUSHER INC.
Hahahaha, I know, I was juss messin' with ya.......
  #23
Old 10-01-2017, 11:43 PM
OzFab's Avatar
OzFab OzFab is offline
Originally Posted by anickode View Post
Also depends on the kart and where you ride. If it's a 15mph yard kart that runs on grass, they might do ok. If it's a 40mph kart that runs on tarmac and does a lot of hard cornering, they will scrub bald and the hubs will snap off in no time.
My daughters kart had those on the front & I'm using them on the twin karts which will only do around 15mph around the yard; any faster than that & I'd be spending a lot more...
  #24
Old 10-01-2017, 11:46 PM
Dustin2017 Dustin2017 is offline
SPP_MN
I think we all got the point and there not worth buying.maybe I'm the only one that gets it.
  #25
Old 10-02-2017, 01:20 AM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
No, the point will never be made. If you do a forum search, the same topic comes up a sextillion times.
They are not go kart tires/wheels and there's not a product description anywhere saying they are. It could conceivably be a confusion with Northern Tool & Equipment which is HF's closest competitor whom actually sells bona fide go kart wheels...
Maybe this was a thread designed to troll the forum?
  #26
Old 10-03-2017, 06:49 PM
Jedibrad Jedibrad is offline
Wonder if these would be any good? Looking for some "4 knobbys
https://www.ebay.com/i/272607898096?...D1326216687795
---------- Post added at 08:49 PM ---------- Previous post was at 08:44 PM ----------
Or these...?
http://www.ebay.com/itm/252723290443...MakeTrack=true
  #27
Old 10-03-2017, 06:52 PM
Hellion's Avatar
Or these...?
Nice hijack.
Those are not HF tires. If they were, I'd say SURE, GO AHEAD
I'd make your own thread, because this one is for the obvious purposes of satire.
  #28
Old 10-03-2017, 07:01 PM
SPP_MN
All I can say is they say for go kart
  #29
Old 10-03-2017, 07:23 PM
Hellion's Avatar
You clever man, you. Nothing gets by you.
I'ma keep an eye on you.
